AVS › AVS Forum › HDTV › HDTV Technical › Projector Interrupts Satellite Signal
post #1 of 3
I connected my projector (Panasonic AE7000) up in our new media room. Now whenever I have it on, the satellite signal goes nearly dead in other rooms in the house. Can anyone explain this? Some channels still work but many of the other channels just show "searching for satellite signal"
Details:
DirecTV
Dish is remotely located about 60ft from the house due to trees
Projector on = low signal which is immediately restored when projector is turned off.
No satellite receiver connected in media room, just other rooms in the house.
I would appreciate any help or advice. Thanks!
post #2 of 3
You might want to define "connected" a little better. Details of what you connected from where or to what and how.
Though I'm suspecting a ground loop issue.
post #3 of 3
Is there a satellite outlet in the media room? If so, is there a terminator on it?
  Back to Forum: HDTV Technical
