AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Flush ceiling mount for Sharp Z30000
post #1 of 2
Hello -
Looking to install a Sharp Z30000 as flush to the ceiling as possible.
The install room has the entrance door directly opposite the screen wall, but because of a step-down, I can install the PJ on-axis if it's inverted and I can use a mounting plate as close to the ceiling as possible (within 1-2in).
The best solution I came up with so far is from Chief Mounts - RSAU:
RSAU - Mini Universal RPA Projector Mount
Any other thoughts or alternatives?
I have plenty of room on either side of the door if the PJ is too obstructive, but would like to keep it on-axis as much as possible.
Thanks -
Gear mentioned in this thread:
post #2 of 2
How close is the screen to the ceiling.. you sure you got enough shift to get it down on the screen? A picture would be helpful so we can see exactly what you are talking about.. Why do you need it on axis that is the great thing about this projector it has shift.. wall mount it next to the door, or is there an HP screen involved?
