AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What are the built-in memory and cpu speed of LG xxLA8600?
post #1 of 5
Hello everyone,
I have spent a lot of time to find out the built-in memory and cpu speed of LG xxLA8600 3D Smart TV before I make a decision to buy, but can't find any information about that. If you owned this TV, you can find out the built-in memory of LG xxLA8600 by clicking the HOME button on the remote control, then click the link "My Apps". A new screen will show the total amount of built-in memory on the top right corner of the screen. I appreciate for any information about this TV.
post #2 of 5
Can't you find one in a store and do the same?
post #3 of 5
Thank you for your response. Right now, Futureshop.ca and Bestbuy.ca don't have this model in their stores. However, I just found out from one website said that LG xxLA8600 has 4GB of memory, but I would like to know the ACTUAL amount of memory left for web browsing. I would be great if I can find out the speed of the cpu of this model.
post #4 of 5
LG spec sheet? LG Support?
post #5 of 5
I couldn't find any information about RAM or CPU speed from the specification sheet. I already chatted with LG Tech Support of Canada. I just waste my time to chat with her.
