AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Which drop amp should i get? (comcast digital cable and internet)
post #1 of 21
I have Comcast Digital Cable (Digital Preferred), and Blast! Internet (50mb/s). and i have intermittent issues from a low signal, when the signal gets below -20dbmv (QAM256) on my modem and/or any of 3 cable boxes, the tv pixelates, or the channel just says one moment please, and internet speeds drop to 0.2 mb/s.
Here is a link to all the necessary info on my situation
http://oi44.tinypic.com/2q8x212.jpg
Which of these 3 amps is right for me?
1- http://www.amazon.com/Motorola-Booster-484095-001-00-Bi-Directional-Amplifier/dp/B000066E6Y/ref=sr_1_1?ie=UTF8&qid=1373264129&sr=8-1&keywords=motorola+drop+amp
2- http://www.amazon.com/Motorola-Signal-Booster-BDA-S1-Amplifier/dp/B00122FCRG/ref=sr_1_9?ie=UTF8&qid=1373264129&sr=8-9&keywords=motorola+drop+amp
3- http://www.amazon.com/Motorola-Signal-Booster-1-Port-Amplifier/dp/B003T2RY7I/ref=sr_1_3?ie=UTF8&qid=1373264129&sr=8-3&keywords=motorola+drop+amp
Edited by MikeF15 - 7/7/13 at 11:39pm
post #2 of 21
Call Comcast, blindly replacing amps is not a proper solution IMO. They can get a tech out to properly troubleshoot the issue, which could be many things... Even before your house at the tap.
post #3 of 21
well i did a lot of in depth trouble shooting myself, i actually hooked my modem and router up outside at the end of the RG11, before the splitter, and it was -2dbmv on qam256, and i heard the qam256 reading off the tap should be +6dbmv, and after 210 feet, RG11 would loose around 8dbmv, which puts it at -2dbmv, where it was, which shows that there isnt any PROBLEM with the drop, its just really long, making it hard to split more than once without having the signal out of the comfort zone.
post #4 of 21
How many ways do you split your drop? 18dB loss after the ground block is excessive. Did you happen to check the upstream level too? That will determine if you need a passive or active return. Also "i heard the qam256 reading off the tap should be +6dbmv" is pretty meaningless without referring to a channel number (frequency), as is your loss figure for RG-11. But I digress. Find that 'missing' 18dB and likely you don't need an amp.
post #5 of 21
All that info is in the first link, after the ~8db loss from the 4 way split, the 5-10db loss after the splitter doesn't seem bad for the distances of the lines.
post #6 of 21
The thing that bothers me a bit is that you're saying it's intermittent, this means it could be the amp dropping out from time to time, but it could also be other things. What are the recorded levels when it's working fine?
post #7 of 21
First I don't have an amp. And it usually is between -20 and -15, mostly near -15, problems start showing if it drops around -19.
As far as intermittent, it can vary over the course of weeks. Which a ~5db fluctuation is normal, I'm just dancing around the border line.
I was just wondering which amp I should use because of the effect on the upstream level and snr im getting Which is all shown in the first link I posted.
post #8 of 21
Ok that makes more sense, honestly Comcast would probably come out and fix it for free but I don't know all the details of the situation. It does sound as though the signal is just underpowered, and you've actually done a decent job troubleshooting it.
post #9 of 21
Mike you have a line problem that Comcast needs to come out and fix. If you amplify crappy signals you just end up with a stronger crappy signal.
Get the line problem fixed first then if needed get the tech to give you a amplified splitter.
post #10 of 21
Sorry, I don't click on links. Is there a reason you didn't host it here as an image?
post #11 of 21
They were to some Motorola drop amps at Amazon.com -- 1 with an active return and the others with passive returns. Posting 3 links is easier than posting 6 images (a photo of the thing and a spec sheet for each).
post #12 of 21
Oh, the Amazon links make sense and I trust them. Links to a tiny URL service is what I won't click. Why post this: http://oi44.tinypic.com/2q8x212.jpg instead of an in line image? Similar problem is the people who post pictures as attachments, forcing you to download them to view them. I won't do that either.
post #13 of 21
Tinypic is just a image hosting site. The pic was too big to host here probably
post #14 of 21
Ahh, I didn't see the tinypic one.
There is one you can get that is adjustable on both the forward and return paths (up to 15dB gain on the forward and up to 10dB gain on the return) for less than the Moto one that has an active return.
Edited by egnlsn - 7/9/13 at 9:39pm
post #15 of 21
I think Huddler has a very generous size limit. As an experiment I just uploaded 15 14.1 MegaPixel images from a friend's wedding. All 15 arrived fine.
post #16 of 21
so...which amp should i get?
post #17 of 21
Which one does your cable company recommend? I'm not convinced you need an amp. 18dB sounds like a wiring problem to me.
post #18 of 21
Like I said -
6db at tap
210 feet to RG11 (-8db)
4 way split (-7.5db)
Distance of runs (- ~5db)
plus fluctuation of signal
All seems to add up to where the levels are reading. (around -15 to -17)
post #19 of 21
Your cable modem is pumping out only 45dBmV, which says you probably don't need an amp with an active return.
The 484095-001-00 has been discontinued, so I guess that leaves one from which to choose.
post #20 of 21
So I should get the bda-s1?
post #21 of 21
Out of those, that's the one I'd get.
  Back to Forum: Cable, Digital Cable - Non-HDTV
