AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Tone control only seems to boost mid bass on an Onkyo TX-SR605
post #1 of 2
Hello,
I was wondering if anyone could help me out with a problem I have been having. Usually I listen to music with no EQ but sometimes you just need to crank the bass. cool.gif Anyway, when I use the tone controls (Bass, Treble) on the receiver, only the upper bass around 80hz seems to get a boost. All the low stuff around 40hz is at the same level as without the EQ. Is there anyway to get the low bass to be boosted as well? It sounds really bad when there is a mid bass hump.
post #2 of 2
There is no way to boost exact frequencies with the tone controls. There really aren't low bass frequencies in most music anyway.
