AVS › AVS Forum › Audio › Home Theater In A Box › Sub/Sat under $1000
Sub/Sat under $1000
post #1 of 9
What does the community think the best Sub/Sat system is for under $1000. Bigger isn't always better, and there's the wife acceptance factor.
post #2 of 9
That's way too broad a question as there are a huge number of good answers. Do you have specific requirements for sound, features, and aesthetics?
post #3 of 9
You should post this in the Speakers forum where you will get many more responses.
With a $1000 budget you don't need to be in the HTiB area.
You will need to be more specific though as there is no consensus best sub/sat system. Also provide your room dimensions.
A good start might be something like 5 of these Energy V-Mini speakers or 5 NHT sats and a SVS compact subwoofer.
http://www.ebay.com/itm/Energy-Veritas-V-Mini-C-2-Way-Center-Channel-Speaker-Each-Rosenut-/350598928832?pt=Speakers_Subwoofers&hash=item51a15319c0
http://www.nhthifi.com/Bookshelf-speaker-SuperZero-2-1?sc=12&category=3772
http://www.svsound.com/subwoofers/sealed-box/sb-1000#.Udy3eayOk4E
post #4 of 9
I am looking for satellites I can mount on the wall without hitting a stud, if thats possible. I did listen to a kef 105 setup and it sounded really good to me. I currently have a set of celestion F30 tower speakers, Klipsch RC52 centre and no name surrounds. I want something that sounds better than what I have but in a much smaller form factor.
post #5 of 9
I don't know anything about your Celestion speakers but the RC52 is a larger center channel. Doubt a little satellite center can compete with that.
I've owned sat/sub systems and then replaced with bookshelf or tower speakers. The bookshelf/towers always sounded better.
the laws of physics are in effect here. you wont get bigger sound from much smaller speakers unless the larger speakers are not very good.
post #6 of 9
Try Cambridge Audio Minx speakers.
post #7 of 9
How would buying the matching bookshelfs to the centre channel work if I hung them on the walls. The only reason I wanted a satellite set was to have a better acceptance factor
post #8 of 9
The RB-51 are the matching bookshelf speakers and they do have a keyhole slot so they can be mounted on the wall.
If you want to angle them you can use something like this bracket.
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI/ref=sr_1_6?ie=UTF8&qid=1373522802&sr=8-6&keywords=pinpoint+wall+mount
post #9 of 9
Thanks guys I went with a klipsch RB 41 II's for the surrounds and Rb 51's for the fronts with my rc 52 for the center. I hung the bookshelfs on the walls and put the center on my AV cabinet. I am using an Klipsch 8' sub for the lows. I will have to say I am happy with the aesthetics and the sound quality. Gotta Love the efficiency of klipsch.
  Back to Forum: Home Theater In A Box
