AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Magnavox 535 all timers gone
post #1 of 3
I went to watch a recording from last night on the Magnavox 535 and all the timers are gone! There were about 10. I added back a couple of timers and it still shows on the bottom 1/1? If this thing crapping out? I've only had it a couple of months. I have called Funai in the past and they told me if it's under warranty I have to send it back on my dime and it can be weeks before I can get it fixed and sent back... That is really bad customer service.so I don't even want to call them on this issue.
post #2 of 3
Your "Timer Programming" menu will show page 1/1 until you fill up the 1st page (6 timers) then create a 7th timer to go to page 2/2.
Not sure why you lost your timers... normally only happens when there's a power outage over 1-2 hours, but then there will also be no clock. Check to see if you have a clock time.
I wonder if you're confusing timers and titles since you said you went to watch a recorded program (title) and noticed your timers were gone, which are in a diff. menu.
post #3 of 3
No I 'm not confusing them. I went to watch a title and it wasn't there. That's when I went to the timers to check and they were all gone, so if they were gone, there was no timer to record... This tells me that it happened before 12:00am... and no there was no power outage. My clocks were even blinking from power outage LOL This dvr is soooooooooooo slow to change channels anyway.
  Back to Forum: DVD Recorders (Standard Def)
