AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › HELP - Sony Bravia R45 Picture Quality
post #1 of 4
First off I want to make it clear that I am a plug and play kind of guy and this is my first HDTV. I'm lost! smile.gif
I just unboxed a new Sony Bravia R45 and I am having trouble getting the picture to look good. I can get it close but all the items that are supposed to be red on the screen are very dark. I know that the TV's color is fine because when I plugged in flash drive and looked at pictures they appeared clear with no variation in color.
post #2 of 4
So we know the flash drive input is ok, but you didn't say which inputs don't look ok. If you have something connected via the component input I would check the red (Pr) input connection.
post #3 of 4
I have the TV set up through the component inputs. I'll check those as suggested. Thanks If that doesn't work in my favor I was thinking about hooking up the cable via HDMI.
post #4 of 4
Thread moved to proper forum.
