AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vizio 80" M801D-A3 owners thread
Vizio 80" M801D-A3 owners thread - Page 25
post #721 of 892
Originally Posted by JoeMorrow7 View Post
Does anyone know if any of the VIZIO remotes w/keyboard work with TV (M801D-A3)?
Or can we use a regular USB big keyboard like on desktop computers? :P
post #722 of 892
Originally Posted by Jidonsu View Post
Why not run the HDMI from the Apple TV and the UVerse to the 103's HDMI inputs so only one cable is between the 103 and the soundbar? With any other bluray player, Vizio's suggestion is pretty normal since the soundbar acts as a receiver.
Well I finally have it hooked up correctly. I ran 1 HDMI from the Vizio TV to an output on the OPPO 103. I then ran HDMI's from the Uverse and AppleTV to the two inputs on the 103 (front and back) and another HDMI from the 2nd output of the 103 to the input of the Vizio soundbar. I then consolidated my 5 remotes using a Harmony Ultimate remote which is really working fantastic. Thanks to the various posters with all the suggestions.
post #723 of 892
Anyone know if the VIZIO XRT303 Remote Control will work with the M801D-3A? It looks like it would, but it was released before this TV. This TV is not listed on the Amazon product page for the remote.
post #724 of 892
Still trying to get firmware update, VIZIO says, Update? What update?
Just got off the phone with VIZIO tech support. The rep told me that the firmware I have (V1.08.12.0000) is up to date. She said it was the latest version as of July 2013. I told her that there is a newer version that adds WIFI capability to the remote. She said she has no information about that. WTF??? Is VIZIO based in Area 51? Did the newer update get pulled for being buggy?
post #725 of 892
Just curious on the semantics. Did you ask "What is the latest firmware (that includes wifi remote support)?" or did you ask "Is 1.08.12 the latest release?" The difference being that some front-line drone just placated you with a made-up response versus them telling you the specific release version.
post #726 of 892
After sitting down with SpectraCal's CalMan 5 I have dialed in a very accurate white balance/color temperature at 6557K (6503K would be reference) on the M801d-A3. These setting apply to my set and I cannot speak if they will work across the board.
Color Temp
Normal
Red: 173
Green: 128
Blue: 109
Red: 85
Green: 101
Blue: 112
Edited by PlayNice - 12/30/13 at 7:27pm
post #727 of 892
I was pretty specific.  I did tell her that I was running 1.80...  I did specifically mention the WiFi remote update.  I am going to call back in a minute and see if I can get past the the front door flunky.  I will repost after.
post #728 of 892
Just got mine up and running, was delivered this AM, and it says Version V1.08.22.0090.
post #729 of 892
What are your other settings? Sharpness, contrast etc.?
Color Temp
Normal
Red: 173
Green: 128
Blue: 109
Red: 85
Green: 101
Blue: 112
post #730 of 892
***2D
Calibrated (for day/lamp)
Backlight: 50
Brightness: 57
Contrast: 49
Color: 30
Tint: -6
Sharpness: 3
Calibrated Dark (dark)
Backlight: 35
Brightness: 54
Contrast: 49
Color: 30
Tint: -5
Sharpness: 3
***3D
Backlight: 50
Brightness: 58
Contrast: 50
Color: 30
Tint: -7
Backlight: 40
Brightness: 58
Contrast: 49
Color: 30
Tint: -8
Color Temp for all
Normal
Red: 173
Green: 128
Blue: 109
Red: 85
Green: 101
Blue: 112
All advanced settings off except I have
Smart Dimming: On
Smooth Motion: Low
post #731 of 892
I still get the pixelated small rectangle blocks when viewing. Hi def TV. Seems to go away when
viewing 1080p blu ray. The blocking and motion adjustments don't help.......reducing sharpness helps a little.
post #732 of 892
My guess would be that you're seeing compression artifacts from your cable or satellite source. With a TV this big, you're seeing things that were there all along, but on a smaller scale in a smaller TV. The fact that you're not seeing it on blu-rays would suggest that it's not the fault of the TV.
post #733 of 892
Another way to test it is to try OTA (over the air) antenna if available. OTA is supposedly has better picture quality than cable and satellite services due to their heavy compressions. To my old comound eyes, I could tell minor differences close up.
post #734 of 892
Yes, I agree with your observations. With Comcast trying to offer 10,000 compressed channels something's got to give. What makes me laugh is how in the hell do they think they are going to offer hd4k resolution if they can't even give you a decent 1080p signal!?!?!? Unless they go fiber optic from source to the set, HD content is doomed for anything cable or satellite related.
post #735 of 892
Oh and PS, it's NOT even 1080P! Its 1080i that looks even worse.......
post #736 of 892
Damn interlaced. I was watching http://www.youtube.com/watch?v=CviEeDRBr6w in 720p, and it had interlaced. Ugh!
post #737 of 892
Hold time must be a BITCH right now!
post #738 of 892
That is seriously funny, sorry, I did not get anywhere with that second call. VIZIO obviously is remaining tight lipped.
post #739 of 892
Vizio got it right on the 80" or is spending more money on their flagship model to reduce it.
post #740 of 892
I just purchased this TV and is being delivered on Saturday and have Sanus VMPL3 wall mount. Does anyone by chance have the dimension from the bottom of the TV to the bottom VESA mount, since the mounts are centered vertically?
Edited by bshullaw - 1/14/14 at 10:02am
post #741 of 892
Just took a tape to it, and it appears to be about 19.5" - 20" from the bottom horizontal edge of the wall-mounted part of the mount to the bottom of the TV.
Also, here's an unrequested suggestion - use the pivot mounts on the TV, not the flat mounts, even if you don't plan to tilt it. I can just barely get my hand up between the TV and the wall. I don't think there'd be a chance with the flat mounts.
Good luck, and I hope you love your Vizio half as much as I love mine!
post #742 of 892
Sorry for being ignorant, but what are those pictures?
post #743 of 892
I think he meant to post in the other thread
post #744 of 892
Is he trying to illustrate a deficiency? What other thread?
post #745 of 892
He was likely responding to this:
http://www.avsforum.com/t/1452199/official-vizio-m-series-razor-mxx1i-thread/7080#post_24206695
And he's probably correct, the 80" appears to be best set in the M-series. Very happy with mine.
post #746 of 892
I just got my second M801d-A3 and this set looks better than the last one. I traded it cause of a dead sub pixel. The color temp settings are very different and I am on the latest firmware.
Does anybody here have this latest firmware and if so does the screen flash white at 100% when changing inputs? My last set did not, but it was on the earlier firmware.
post #747 of 892
Perhaps you could tell us what "latest firmware" is.
post #748 of 892
V1.09.38.0090
post #749 of 892
Wow. I wouldn't want my picture to be impacted by a firmware update. I didn't do a calibration but I am using settings posted here that work pretty good for me. Considering not many have this firmware it will be difficult to find people who have calibrated with it. Are you thinking of calibrating again?. I think I am using some of the settings you have posted.
V1.09.38.0090
So this is the one that enables wifi on the remote correct? not that I care, just curious. Was it a new (factory sealed) tv? Must have been manufactured pretty recently to have the latest firmware. I think that rules out Vizio having any problems with it, they just don't know how to put it on existing TVs.
post #750 of 892
Thanks, I really appreciate you taking the time to do that. I currently have an 80" Sharp mounted that this TV is replacing due to severe light leak and clouding . I currently have the 1" standoffs mounted on the flat mount which allows me to get back there, so hopefully that will remain with this TV.
