AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › HD webcam over USB Balun
post #1 of 3
Does anyone know of a way to extend a USB HD webcam over 60ft?
I am using a Microsoft Lifecam Studio with 720p streaming. I have tried different brands of usb over single cat5 baluns with no success. the first issue was my fault because I wasn't buying baluns that were rated for the full 480MBPS that usb 2.0 supports.
So I then bought one from a military component website that was rated for 480MBPS and still nothing.
Trying to use this in a conference room for skype where the PC is located about 30ft from where the camera needs to be, which would require about a 50 ft run of cat5. all the baluns I tried were active btw, all had power adapter.
post #2 of 3
Have you considered using an active USB extension? I know the Kinect has a similar issue to this and would only work with baluns that were a few hundred dollars in cost or an active USB cable.
post #3 of 3
Yes I tried a 30' active male-female ext cable.
  Back to Forum: Home A/V Distribution
