AVS › AVS Forum › Video Components › Home Theater Computers › xbmc sevear shutter, Movie un-watchable.
post #1 of 3
Hey guys, I am getting servere shutter in my living room HTPC, so bad that it takes about 2 mins to get through the first comic intro on Avengers (That usually takes only seconds to finish) The basement works great, but that was setup by the guys at Assassin. Is there something in the settings that need to changed or could this be a hardware issue like the PC itself, the router or cabling to the server? I have the AMD A10 5800K apu with 8 gig of memory for the HTPC.
Cheers Dave
post #2 of 3
Try copying the file/movie to the HTPC and playing directly from there - to see if the stutter is due to network/streaming issues.
post #3 of 3
I tried another PC on the same line and it did not have the proble, so I re-installed xbmc and all is fixed. Thanks for the help.
