AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › I want prefect reproduction of the whole sound spectrum
Poll Results: Best sub size
  • 0% (0)
    8"
  • 0% (0)
    10"
  • 50% (2)
    12"
  • 25% (1)
    15"
  • 25% (1)
    18"
4 Total Votes
post #1 of 3
The title pretty much says it all. I tell that to people at local car audio shops and they just give me a funny look. I already have two 10" ...they are way too quiet and don't seem to be able to reproduce the lower end of the spectrum? Does anyone have any suggestions?
When a sub says it can produce 25hz-1000hz is that even true? sounds like too wide of a range also how well can it reproduce those sounds at each point along that stated segment?
I appreciate your time and feedback.
post #2 of 3
Subs don't play to 1000Hz because they don't need to. Usually, they'll play up to ~120-150Hz, occasionally up to ~200Hz (better for integrating with smaller satellite-type speakers).
SVS' subs have a nice, flat FR within a good range. Example: The PB12-NSD, flat from 18-150Hz +/-3dB.
Ditto PSA's subs, like the XV15 (flat from 21-200Hz +/-3dB).
Question is: At what level of output do you still want to see ruler-flat response? Generally-speaking, the louder you go, the less likely a sub will continue to play flat to the lower limit of its rated range.
Re. the vote: I'd go with 15" or 18". Since I can't pick both, and since I have dual 18" subs, I'll vote for 18". smile.gif
Edited by eljaycanuck - 7/10/13 at 5:11pm
post #3 of 3
"perfect" < irony >
Post in the car audio subforum.
