AVS › AVS Forum › HDTV › HDTV Recorders › Channel Master DVR+ Owners Thread
Channel Master DVR+ Owners Thread - Page 6
post #151 of 3123
I had archived the page. Here is the text. If someone has a place to post the whole page for everyone to see, I can send you the files.
Infra-Red Extender for CM-7500 DVR | Channel Master (CM-7500XIR)
Our Price: $24.99
The CM-7500XIR Infra-red extender cable allows you to 'extend' the reach of the IR receptor of the CM-7500 DVR increasing the area of operation for the CM-7500 DVR remote control. Using the IR extender also allows you to place the DVR in a hidden or more discrete location where the small IR extender would be in view for the remote to send operating signals to. As long as there is a line-of-sight between the remote and the IR extender you will be able to control every function of the DVR.
Features Summary:
* Increase CM-7500 remote range
* Gives option to place DVR in hidden space while only exposing the IR extender
* Plug and play easy installation
* Top quality performance
* 72 inches long
Wireless USB Adapter for CM-7500 DVR | Channel Master (CM-7500XWF)
Our Price: $39.99
The Channel Master CM-7500XWF Wi-Fi adapter allows you to enjoy the internet applications and enhanced program guide on the CM-7500 DVR wirelessly. This is a perfect solution if you're unable to run a direct Ethernet cable from your router / modem into the DVR or if you simply prefer reducing the amount of cords connecting to your DVR.
Features Summary:
* Enables Wireless internet connector on the CM-7500 DVR
* Easily plugs in via USB
* Speed: Up to 300mbps
* Interface: USB 2.0
* Frequency: 2.4GHz
CM-7500 compatible Seagate Backup Plus 500 GB USB 3.0 Desktop External Hard Drive
Our Price: $69.99
The Seagate portable external hard drive works with Channel Master CM-7500 DVR which allows you to record and store TV programming directly to this hard drive. This hard drive features 500 GB of storage and conveniently plugs into the DVR through USB port. This hard drive can also be used as backup hard drive for other storage applications
* Compatible with Channel Master CM-7500 DVR
* 500 GB storage capacity
* Can be used for many other backup and storage applications
* Interchangeably load files on your PC or your Mac computer without reformatting
* Dimensions: 4.47" x 2.99" x 0.38"
* Weight: 0.33 lbs.
* Color: Black
* Interface: USB 3.0
This product includes:
* Seagate slim drive
* Seagate Dashboard Software (pre-loaded on drive)
* NTFS Driver for Mac (pre-loaded on drive)
* 18in. USB 3.0 Cable
* Quick Start Guide
* Two-Year Limited Warranty
CM-7500 compatible Seagate Backup Plus 1 TB USB 3.0 Portable External Hard Drive
Our Price: $94.99
The Seagate portable external hard drive works with Channel Master CM-7500 DVR which allows you to record and store TV programming directly to this hard drive. This hard drive features 1 TB of storage and conveniently plugs into the DVR through USB port. This hard drive can also be used as backup hard drive for other storage applications
* 1 TB storage capacity,Spindle Speed 5400 RPM
* Dimensions: 4.86" x 3.19" x 0.57"
* Weight: 0.44 lbs.
* Color: Black
* Seagate Backup Plus Portable Drive
* USB 3.0 Interface Adapter
* 18in. USB 3.0 Cable - also backward compatible with USB 2.0.
* Quick Start Guide
CM-7500 compatible Seagate Backup Plus 3 TB USB 3.0 Desktop External Hard Drive
Our Price: $124.99
The Seagate portable external hard drive works with Channel Master CM-7500 DVR which allows you to record and store TV programming directly to this hard drive. This hard drive features 3 TB of storage and conveniently plugs into the DVR through USB port. This hard drive can also be used as backup hard drive for other storage applications
* 3 TB storage capacity,Spindle Speed 5400 RPM
* Dimensions: 6.22" x 4.88" x 1.73"
* Weight: 2.38 lbs.
* Color: Black
* Interface: USB 3.0 - also backward compatible with USB 2.0.
* Quick Start Guide
Subscription Free Digital / HD Antenna DVR | Dual Tuner - Channel Master CM-7500
Our Price: $249.99
(no description)
3 Year Warranty plan for CM-7001 / CM-7500
Our Price: $28.99
Enjoy added comfort and protection with the 3 year warranty plan offered by Warrantech which increases the warranty period of your product in the event your unit is rendered inoperable due to a mechanical or electrical failure during the 3 year time frame of this agreement.
If your product defects during the 3 year period, Warrantech will either replace the product with a new or refurbished unit with equal or greater features and functionality.
You will receive a hard copy service plan card which includes registration number and additional information, this will ship with your unit. To review the service agreement details, please click here
This extended warranty agreement is only eligible for new purchases of the Channel Master CM-7001. It will also be eligible on the new Channel Master DVR which is expected to hit shelves early 2014.
post #152 of 3123
Do any of you think that Sling functions will make their way into this device?
check out this post form TWICE:
http://www.twice.com/articletype/news/channel-master-dvr-adds-slingbox-support/109094
I think it makes sense since Echostar owns Sling.
post #153 of 3123
Slingbox is compatible with Channel Master’s CM-7000PAL DVR
I would check if the statement is true, if someone will connect such sling-boxes to PC and would publish VID_XXXX & PID_XXXX of these
post #154 of 3123
And once again the countdown timer is gone from the CM site.
Sorry if this is the wrong forum for this but do any of these PVRs have analog input such as component so that they can be used as a general purpose recorder for all sources including those originating from HDCP controlled sources?
post #155 of 3123
I just got a call from Joe at Channel Master.
My order for the CM-7500, 3TB drive, wireless adapter, infra-red extender, and 3-year warranty has been canceled.
They have no product to ship.
The pages that were previously viewable on the web site were not supposed to be available for the public to see yet.
Update from him is that the product is still in the works, and is not finalized yet, things are still being changed on it.
He said the release goal is for the first quarter of next year, and I should look for them to notify me then when it's available. Expect nothing before January 1st.
Joe, if you see this (and I assume you at Channel Master are following this) please have someone from your company join the discussion here and keep us updated.
We're all drooling to see what this is capable of, and as you have found out, some of us are very eager to get our hands on one.
You wouldn't happen to have a couple free samples of these to be sent out to be beta tested, would you?
post #156 of 3123
nope, no encoders inside - just check specs of STi7109 (or any CPU inside of other DVR/PVR)
post #157 of 3123
Well, I guess the component to HDMI devices are around but do any of these boxes allow recording from an HDMI input (non-HDCP)?
post #158 of 3123
No. They are made to record by spooling the digital transport stream of the broadcast source.
If you want analog input capability you need to buy either a PC capture device like the Hauppauge HD-PVR (HD or SD recording) or a DVD recorder (SD recording only).
post #159 of 3123
Yeah, for PC-free general input HDD recording looks as though you have to go pretty low tech like the Avermedia. At least it's cheap at BestBuy, etc.
http://avermedia.com/AVerMediaPVR/products.asp
Thanks for giving me a little off-topic bandwidth.
post #160 of 3123
That may even be optimistic. Remember it took almost a full year for the DTV Pal DVR to come out after announcement.
post #161 of 3123
I'll volunteer to be part of that testing group as well. Just in the interest of improving the end product, you know biggrin.gif
post #162 of 3123
Common to both models:
[*] PSIP guide if not connected to Internet
[*] 14 day guide service (Rovi) from Internet - no charge for guide so far
The Rovi guide has me scratching my head -- I didn't think their Internet guide for HDTV's went much beyond 3 days. This must be something different.
Does anyone have more news on the possible guide data for this? This is all I could find on the Rovi website:
Overview: http://www.rovicorp.com/products/discovery/guides/totalguide-ce.htm#overview
.pdf description of TotalGuide: http://www.rovicorp.com/webdocuments/product_literature/rovi-totalguide-ce-product-details.pdf?link_id=
From the investor relations site, news that the Xbox One will use Rovi data: http://ir.rovicorp.com/file.aspx?IID=4206196&FID=20816712 Quote from release: "Rovi Corporation ... will supply data for the TV electronic program guide experience, OneGuide on Microsoft's Xbox One."
Hopefully this will last longer than the TVGOS data did on the DTVPal DVR.
post #163 of 3123
I can only tell you that the guide information is supplied by Rovi over the Internet and it is a 14 day guide. I have no information on whether or not the guide information will be free, but I will find it very surprising if there is not a nominal subscription fee associated with a 14 day guide like there was with the CM-7400. If the guide is coming directly from Rovi and not through a 3rd party (like with the CM-7400) it speaks well for its continued availability. Of course, nothing is ever certain -- you pay your money and take your chances.
post #164 of 3123
perhaps E* still have legal leverage of ROVI as before ?
post #165 of 3123
It's interesting that the last item indicates that the address space allows up to 3GB HHD upgrade for those who wish to change the internal HHD to a larger unit.
post #166 of 3123
I think you meant 3TB.
post #167 of 3123
The Seagate STCA3000101 portable external hard drive works with the Channel Master DVR+ to expand your recording capacity up to 360 hours of HD recordings.
* Compatible with Channel Master DVR+ (CM-7500)
* 360 hours is estimate based on normal use, Actual recording capacity will vary based on the bit rate of the broadcast
* Weight: 2.38 lbs.
* Color: Black
Here is a quota with the link between names.
post #168 of 3123
Oops
post #169 of 3123
Originally Posted by andy416us View Post
I think CM is using a different name now for this DVR. They refer to it as "DVR+" in several of these links:
Yes, that is true. The model is the CM-7500 but the docs also refer to is as the "DVR+"
post #170 of 3123
I hope the name doesn't cause a conflict. There already is a "DVR Plus" on the market.
http://www.optimum.com/digital-cable-tv/dvr/dvr_plus.jsp
post #171 of 3123
It will probably be referred to as the "Channel Master DVR+" (model CM-7500GB16 or CM-7500GB320)
or possibly the "CM-7500 DVR+"
post #172 of 3123
That name reminds me of the VCR+, or, as I think it was redundantly labeled, the VCR Plus+.
post #173 of 3123
I think "DVR Plus" is a service, not a physical DVR. But the name is close enough to cause confusion, possibly.
Not sure what CM thinks the "+" is. The only thing I can imagine is Vudu - but the CM-7400 had that and they didn't call it a "DVR+" confused.gif
post #174 of 3123
The links I posted about the DVR+ name takes you to the Channel Master Authorized Dealer page now, so I'm deleting the post.
post #175 of 3123
post #176 of 3123
Channel Master
DVR+
249.99
Very sleek only 1/2" high.
I didn't see a model number--CM was really pushing the model as
DVR+
post #177 of 3123
Originally Posted by MarkB49 View Post
Channel Master
DVR+
249.99
DVR+
It's listed right under the price as "Product Code: CM-7500GB16 ".
post #178 of 3123
Originally Posted by wizwor View Post
http://www.channelmasterstore.com/DVR_p/cm-7500gb16.htm?Click=32508
Merry Christmas!
Thank you, I've placed my order.
Changes from the earlier page posted in November:
Price on Seagate backup drives has been increased.
Extended warranty backed down from 3 years to only 2, and the price increased.
Price for the IR extender decreased.
post #179 of 3123
This thing looks pretty sweet, I sure hope it works. I'll be watching reviews.
post #180 of 3123
What's to stop Tivo from suing these guys until they pull or cripple this? It's a dvr, and it has a guide via internet. That's usually all Tivo needs for a target...
I hope it works, because I want one...
  Back to Forum: HDTV Recorders
