AVS › AVS Forum › A/V Control & Automation › Remote Control Area › HK AVR 7200 Remote Completely Dead
post #1 of 5
I went to use the subject remote (actually had it stored in its package with batteries removed) which had not been used in probably more than a year and. I installed brand new batteries in it and there were absolutely no signs of life. I went through a "reset" procedure of pressing every button on the remote for 3 seconds in turn with the batteries and then replaced the batteries and still nothing.
I then took the remote apart and although I saw no signs of contamination inside it, I cleaned each contact point and the control button backs with Isopropyl Alcohol and put the remote back together with no success. The battery contacts were clean and all looked secure and there was a piece of what appeared to be insulating tape on the back of the circuit board where the battery contacts that are attached to the back of the remote could rub on the circuit board which looked to be intact as well.
I could see no signs of cracking in the circuit board or burn spots on the board or components mounted on it. Has anyone else experienced this type of issue with a hardly used AVR 7200 remote control? The online replacement remote control places don't show it available (except for possibly one), but they do show that the DPR 1001 remote is a replacement for it. Visually it appears to be the same other than the name on the remote saying "DPR 1001" instead of "AVR 7200". Prices seem to range from $130-$200. I just missed an opportunity to buy an entire AVR 7200 and remote on Craigslist in my area for $250 a couple of weeks ago.
I don't know if it would be worth trying to take my remote into a local HK authorized repair center or not. I've taken things to them in the past, but the last time I called them they said they had gotten very selective on what HK items they would now attempt to repair because it was difficult getting parts from HK.
Any assistance is greatly appreciated.
Best Regard,
Ted
post #2 of 5
The question is - remote or IR receiver on the unit. If the remote a cheap universal replacement remote will do the trick. If the IR receiver in the unit, well then your problems are bigger. You did try new batteries, right?
post #3 of 5
It is definitely the remote, and yes brand new batteries were installed when I took it out of storage. The remote has an LCD display built into it which is inactive. It also has a light button to back light the buttons on the remote and this does not work either. I also pointed the remote at a video camera which would normally "see" the IR emitter signals that cannot be seen with the naked eye and it saw nothing. It is definitely the remote.
Finding a universal remote that will replace it is difficult. I do have a Harmony One that can control some functions, however, there are certain functions that are unavailable even with it.
post #4 of 5
Double check that both batteries are inserted in the correct direction.
We do know 55 IR signals for the AVR 8000, and I believe these will also work with the AVR 7200. So it is practical to use a universal, although names like "Neo 6" won't be on hard buttons. A RCA RCRP05B (or a cable company Atlas) can be manually programmed with the following 5 digit EFCs, or these code can be converted to Pronto Hex, and loaded into e.g. a Harmony. Signals are NEC1 128.112 or 130.114. Warning: Spoiler! (Click to show)
Code:
Button       EFC     dev.sub OBC
0       14053   128.112 158
1       64229   128.112 135
2       30181   128.112 136
3       31205   128.112 137
4       30693   128.112 138
5       31717   128.112 139
6       29925   128.112 140
7       30949   128.112 141
8       30437   128.112 142
9       14565   128.112 157
vol up  60133   128.112 199
vol down        26085   128.112 200
mute    59877   128.112 193
tuner up        62693   128.112 132
tuner down      63717   128.112 133
power on        58853   128.112 192
power off       15077   128.112 159
tuning -manual  48101   128.112 147
memory  63205   128.112 134
direct  15333   128.112 155
dvd     42469   128.112 208
cd      58597   128.112 196
video 1 26597   128.112 202
video 2 27621   128.112 203
video 3 26341   128.112 206
video 4 43493   128.112 209
video 5 50661   128.112 240
am/fm   63973   128.112 129
tape    25829   128.112 204
6 channel       11173   130.114 219
test    29861   130.114 140
channel 08357   130.114 93
speaker 41893   130.114 83
digital 40101   130.114 84
delay   40869   130.114 82
up arrow        30629   130.114 138
down arrow      31653   130.114 139
right arrow     59301   130.114 194
left arrow      59813   130.114 193
set     62629   130.114 132
night   46757   130.114 150
preset scan up  42405   130.114 208
preset scan down        43429   130.114 209
multi-room      10917   130.114 223
osd     07333   130.114 92
clear   10405   130.114 221
logic 7 06053   130.114 162
surround        07589   130.114 88
stereo  15269   130.114 155
dolby   40357   130.114 80
dts     05541   130.114 160
thx     13989   130.114 158
neo 6   06565   130.114 161
post #5 of 5
The batteries are definitely installed correctly. The correct positions are clearly labeled in the battery bay for 4 AAA batteries.
  Back to Forum: Remote Control Area
