AVS › AVS Forum › Video Components › Home Theater Computers › best inexpensive HTPC for 1080p movies on external hdd. Advice needed
post #1 of 5
I have almost finished my upgrade ,but will not be able to build a pc att. could you please take a look at these few HTPC that i am looking a purchasing or recommend something that can play all movie format up to 1080p.
http://www.avsforum.com/t/1471083/htpc-brand-new-250gb-hdd-hdmi-4gb-ram-blu-ray-player
http://www.avsforum.com/t/1443921/htpc-for-sale-amd-phenom-ii-x4-gigabyte-atx-4gb-skill-ripjaws
http://www.pivosgroup.com/xios.html
I currently have an Apple Tv gen 1 and it does not do well with bluray quality
post #2 of 5
The first PC uses a newer amd cpu but the hardware is not great. The second PC uses an older CPU but has some nice hardware. One problem I see with the second PC is that it won't bitstream HD audio.
Another option is to get a slim Dell with an i3. I think you should be able to get one for under $500. I know you said you didn't want to build a PC but have you seen the mini computer from Intel? They're called Intel NUC and cost about $300 for a kit.
Edited by Mrkazador - 7/12/13 at 9:11pm
post #3 of 5
I saw you listed my HTPC for sale and I will say it plays 1080p rips perfectly and quickly from my WD 3TB Red drives in Raid 1 in combination with the actual HTPC hardware. Maybe that will be helpful for anyone else in the future looking for a cheaper build like I was.
post #4 of 5
Hey I thought your HTPC was great ,but after asking around some have advised against it. I am still on the fence.
post #5 of 5
Well I'm certainly no HTPC expert but I really liked my cheap build.
- Boots in a good time
- Movies play perfectly and they start quickly
- I use WMC and there is no lag running through the menus
