AVS › AVS Forum › Audio › Audio theory, Setup and Chat › How can I get stereo from my PC to my audio system?
post #1 of 10
I want to watch the video from my PC on my TV and listen to the audio through my audio system.
If I use the HDMI connection from my PC to TV the audio goes to my TV and the speaker jack is overridden.
Any ideas?
post #2 of 10
Your TV should have a digital audio output. Send that to the sound system.
post #3 of 10
Yes it does,I know, thanks. This is what I am trying to avoid.
Long story short I'd need an electrician to come run the wire because it snakes through so much wall and rooms.
I have one HDMI and one set of those multi colored connects/wires from teh tv to the sources. I have to work with these or as I said I'll need an electrician.
post #4 of 10
If those multicolored wires are component video cables, you can use one of them for digital audio. Assuming your TV has an optical rather than coax output, just get an optical-coax converter.
post #5 of 10
I am going to solve it by buying a Blue Ray player with HDMI inputs and use the RCA audio outputs to my Nad and the HDMI for the picture to the set.
post #6 of 10
That will work, too. But, be careful because some newer players lack analog stereo outputs.
post #7 of 10
thanks
post #8 of 10
? a player has no inputs.
post #9 of 10
Take a look at the Oppo 103.
post #10 of 10
Yes, the 103 is perfect.
