AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Problems with Optoma HD33....
post #1 of 3
Hello friends:
I am having trouble powering up my 6 month old Optoma HD33. It was working perfectly fine till yesterday afternoon, but when I tried to restart it again in the evening, nothing happens except the blue power LED keeps flashing. I checked the user manual and all it says that the PJ is either warming up on power on or cooling down after power off. The cooling fan does not start either. I tried by disconnecting the power and reconnecting after 2 mins, but end up with same results. Any suggestions?
post #2 of 3
Originally Posted by Newtron11 View Post
Hello friends:
Did you ever find out what the cause and fix of the issue was? I too am now experiencing this issue. My projector is about 14 months old but with only about 65-80 hrs on it.
post #3 of 3
coming from PC's , have you tried removing power and holding the power button for like 10 seconds to discharge the caps and then replug and try again?
Past that I would suggest calling optoma. Its within Warranty.
