AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Simplest way to use a Harmony IR remote to control a ceiling fan (typically RF)?
post #1 of 2
The RF module for my ceiling fan burned out and the remote for it never worked well to begin with, now that they need to be replaced I am hoping I can install a module that uses IR so I can use my Harmony One with it. I know the censor for the IR would need to be exposed, I am sure I could mod something to work, but is there a IR module that would work directly with the Harmony one? I found this auction for a Lutron Maestro module that claims to be IR; Will that work directly with no other hardware required? If not, what do I need? Install a new RF module and use some sort of IR to RF converter?
post #2 of 2
Hi ThrowingChicken, I purchased the Lutron Maestro IR Kit (MIR-LFQMT-WH) and wall plate (CW-1-WH) and it works great with my Harmony One.
  Back to Forum: Remote Control Area
