AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › If this was your room (Pics)
post #1 of 52
Hello,
I am about to upgrade the subwoofer in my home theater. I just sold my old, original model, Outlaw LFM-1. (Ignore it in the photos.)
I am considering one of two options that are both around $1,000:
HSU VTF-15H
or
Two SVS PB-1000's
The room is a loft space. You can see the opening to the stairs in the photo.
The room is 19 feet long from front to back.
The room is 11' 6" wide with an open set of stairs. As a result, the area behind the couch is about 8' wide.
The couch is 12' 7" front the front wall.
There is about 6' 5" from the back of the couch to the rear wall with the bookcase.
The ceiling slopes upwards towards towards a point above which is a few feet ahead of the couch.
Probably about 1,800 cu/ft and then add on the open staircase.
Currently using KEF iQ 10's for LCR, and older KEF eggs for rears and heights.
100% Home Theater. I crank up the volume at times but not insane SPL's.
I'm torn. The HSU should have lower bass and more impact. But the PB-1000's should go down to 19hz which is fine, assuming they can do it well in my room. They would also offer a smoother response, but my seating area is just one couch, usually just a few people so not sure if that is a factor.
So, if it was your room, which option would you choose?
Dan
post #2 of 52
post #3 of 52
100% Home Theater. I crank up the volume at times but not insane SPL's. ... my seating area is just one couch ...
I'd go with a single HSU VTF-15H ($879 + $143 shipping) or PSA XV15 ($799, shipped).
post #4 of 52
^^^ +1
post #5 of 52
Because of your seating I would go with the VTF hands down. Might you fill me in on what the white cylinders are in your R corner?
post #6 of 52
The white cylinder is actually a floor standing lamp from Ikea.
Alright, I'm definitely leaning towards the HSU.
Dan
post #7 of 52
Originally Posted by r0n1n View Post
I was thinking ported simply to get the biggest home theater experience and genuinely get down to 20hz or so.
Thanks for the compliment!
Dan
post #8 of 52
Checking out the PSA XV15 now. I didn't realize it came with custom veneers. Now I'm very interested.
I'm guessing it's a toss up between that and the HSU--both ported 15's from great designers. Would there be a significant difference?
Dan
post #9 of 52
IMO, the biggest difference is the VTF-15H's tunability: You can block ports for max output / max extension, and the amp has PEQ functionality.
If you think these features could be of use to you in your HT space, you might want to go with the HSU.
If your AVR is equipped with good room EQ software - such as Audyssey MultEQ XT or XT32 - I think it's more of a toss-up.
Either way, you end up with a powerful and well-rated sub.
post #10 of 52
I see the options have increased.. now for the budget. wink.gif I'm thinking dual driver options...
post #11 of 52
Budget: I was thinking $1,000-$1,500.
All in, I'd like to cap it at $1,500. (Shipping, etc.)
The HSU is a great value coming in at just over a grand. Not sure I would increase performance significantly by stretching another $450. But I'm open to all options.
Dan
post #12 of 52
Have you thought about DIY? You could easily build a pair of 15" subs and get a lot of bang for your buck.
post #13 of 52
LOL, I was thinking the same thing.
Back to the subject, If anyway possible, I would go duals. "IMO" You are not going to see a huge difference from the Outlaw with either of the subs mentioned unless you get two. I had dual Outlaws and they really do impress for what they are. If at all possible, I would get two subs. For that room, you should have just added another EX and you would have been set. If you could do it, I would look at the PSA XV-30 or XV-30f or dual XV-15's.
post #14 of 52
I've already purchase two flat packs to build dual 10" sealed subs for a satellite system in my apartment in New York City. (No 20hz happening there with neighbors.)
But between a crazy job, two little kids, and the first floor of the weekend house you're seeing in the pictures above getting wiped out by hurricane Sandy, I can't find any time to build them. Hopefully sometime this summer.
So for the loft of our weekend shore house, I'd rather just buy a sub. Just don't have the time for DIY.
Dan
post #15 of 52
I bought the Outlaw used. It was the first model and probably 9 or 10 years old. I was thinking an upgrade to a 15" with more excursion would be a big step up.
post #16 of 52
At $1500 I wold go for either a single Rythmik FV15HP or dual Hsu VTF3 mk4s. The Rythmik ought to get you more overall output and maybe better sound quality, the Hsus will get you a flatter frequency response and better room coverage.
post #17 of 52
I thought maybe the OP had some kind of special lead pertaining to SVS options or something. wink.gif
That works!
post #18 of 52
At $1,518.10 dual PSA XV-15's would be nice if you could swing that.
post #19 of 52
That works!
Actually, because of the Ikea white cylinder light in the right corner, I was considering buying an SVS cylinder sub and recovering it in white fabric to match. But I'm not sure that it would look good. I did a quick mockup a few weeks ago.
I think a box would be better.
post #20 of 52
with the HSU...
post #21 of 52
LOL.. I would have to agree with you on that. Looks like you have been quite thorough in the mock dept.. smile.gif
post #22 of 52
It's Photoshop
post #23 of 52
Dual PC-12s ($1399) could look good, even in black. The roundness matching not just the cylinder light on the right, but also the roundness of the tables and the speakers up above. They are also not as tall as your mockup, so not as imposing on the rest of the room. Your mockup sub looks like a water heater it's so big smile.gif
post #24 of 52
When I did the mockup, I was estimating the size of the PC-13 Ultra. The space from the window to the wall on the left is about 19" or so. The PC-12's would be smaller. Not sure if black is better...maybe?
Where it gets tricky with duals is the right side of the room. If you look closely, you'll see that there is much less room. The distance from window to wall on the right is only about 7" or 8". And I really didn't want to obscure the window or be right on top of the right speaker. I plan on pulling them out from the corners along the walls though, but i'm not sure if this helps with duals.
post #25 of 52
Now I'm torn...an HSU VTF15...or....an SVS PC12-Plus cylinder....the cylinder look could be cool in this room....not sure though...
post #26 of 52
I think the black cylinder look would be cool as opposed to a black box or white cylinder because you already have a white cylinder light, and white shades, and white round tables. But room aesthetics are definitely a personal thing smile.gif
post #27 of 52
go with duals...for 1500.00 dollars i would go with hsu vtf-3 mk4's or psa xv15's.
post #28 of 52
ReplyQuote Multi
Actually imo the SVS cylinders are very manageable. At 35” tall they're really not that big considering the output. Take note of the three 12+’s all in one corner. That’s how little floor space they actually take. Don’t ever wrap one in white though. mad.gifbiggrin.gif The Ultra is a foot taller so exhibits much more presence (it’s the cylinder by itself) at bottom, but not as large as your mock. I would akin that to a LLT which I have posted for you along side so you can see what you would really be looking at. One of the pics is very grainy due to dig cam at the time, but it still gets the point across.
EDIT> And the same corner with two box style +’s. You can see I had enough room for 4 cylinder +’s as apposed to 2 box style.
Edited by steve nn - 7/15/13 at 4:20pm
post #29 of 52
Steve....you could have stacked 2 more boxed subs on top and had the same height as the cylinders biggrin.gif Okay maybe a little taller, but 4 subs either way
Those cylinders are pretty cool though. Hopefully i'll get to see one and hear one in person someday
post #30 of 52
Ok you caught me. That would be a pretty good size block of woof though. I don’t think WAF would have permitted? Anyway I found the perfect mix stacked and all just for you ousooner2 smile.gif Seriously though.. I hope you get the chance also. cool.gif
