AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Panasonic ut50 codes
post #1 of 2
Does anyone here have the codes for the panasonic ut50? Looking for global cache format.
post #2 of 2
If that's a TV, than any Panasonic TV codes from the past several years will work. They are all the same.
You can also just grab a JP1 upgrade for that device and generate the codes using IRP Master. You'll also need Remote Master to read the upgrade
Edited by mdavej - 7/15/13 at 3:03pm
  Back to Forum: Remote Control Area
