AVS › AVS Forum › HDTV › HDTV Recorders › Moxi HD replacement
Moxi HD replacement
post #1 of 3
My moxi three tuner dvr's HD is getting flaky. I have read the how to and have bought a WD 1tb WD10EURX witch is listed to work. I have two questions. First is replacing the drive goes wrong and I reinstall the old drive will the Moxi work again? The second question is has any one been able to clone the old drive to a new one and have it work?
post #2 of 3
You might want to take a look at this thread.
post #3 of 3
Hay thanks
I have been reading that thread for several days and can not find the link to the cloning software that was talked about, nor have I found any reference to what would happen if I put my old drive back in the moxi box if the HD replacement fails.
  Back to Forum: HDTV Recorders
