AVS › AVS Forum › Audio › Speakers › Do I need a 5.1 sound card ? Please advise
post #1 of 6
Hello All,
I ended up buying today the Logitech z506 surround sound system 5.1
I have to admit that I was very excited till I set up the full system, but now I am listening to the sound, and it is not the killer - for some reason-
my questions;
a) when I called Logitech crew today to ask for some help , the lady advised that I should get a sound card that is 5.1 adaptable for surround systems. Do you guys think that it is worth to pay another $100 for a good sound card? (sound card is more expensive than the speakers itself in this case!)
b) if you advise to get a good sound card, what brand would be a good recommendation?
Thank you all for your opinions!
B.
post #2 of 6
Since you think that your question relates to Home Theater and speakers in particular, I will give you a link that will direct you to a proper forum.
http://www.rage3d.com/board/
post #3 of 6
They are cheap PC speakers, they aren't supposed to blow you away. They will not sound great even with a new sound card.
post #4 of 6
No I wouldnt spend another 100 dollars to try get better sound out of a less than 100 dollar speaker system!
post #5 of 6
Agreed. If they don't sound good to you, take them back and save some more money. smile.gif
post #6 of 6
Return those speakers they are terrible, and get yourself some fluance tower speakers or bookshelf speakers a decent receiver, or swan M50W, or a 5.1 setup polk or something or edifier if you want 5.1 sound, you get them for the same price as the Z906 from NCIX.
  Back to Forum: Speakers
