AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Optica 42" LED /3D , Stuck on customer number , can anyone help with firmware
post #1 of 22
hi everyone i purchased a optica led 7042 / 42" tv (used)
and everything was going fine till one morning turned it on and was greeted with a customer service box
where i had to enter a number
now completely baffled , i have found out the the tv is an exclusive to buy as you view
and have contacted them but with no help
i have also found out that the main board is a cv309h-b (google search , with ppl with similar problems)
i was wondering if anyone can help with a master reset or new firmware , as i can use it and feel ripped off of £300
thanks in advance to anyone who can shed a light or help me
post #2 of 22
post #3 of 22
did you have any luck with your tv coz ive got the same problem
post #4 of 22
I have managed to get a customer number and get past that part
but now my tv is locked and only have offline activation
really annoying
post #5 of 22
really annoying
post #6 of 22
really annoying
post #7 of 22
I have been conned to I think bought the tv and never seen or heard from the buyer again roli can you get a picture ? I couldnt get by the customer number part any info would be a joy
post #8 of 22
hi im having same issue with this tv stuck on customer number any help please. i.e does any customer number work or are they locked numbers for each set
post #9 of 22
As long as customer number is valid it does work . But it will lock again after week as im back to square one again
post #10 of 22
I dis have the tv on for a week . Was working brill activated it onlibe then minute I had picture deactivated the wifi . But now week later locked again and stuck at same screen again
post #11 of 22
What is a customer number made up off I.e numbers letters and how many
post #12 of 22
I have no clue just asks for a customer number
post #13 of 22
ask who????
buy as you view told me to do one lol
post #14 of 22
sorry i meant to say i have no clue . just comes up on the screen customer service no it gives no indication wether it should be numbers or letters
post #15 of 22
Combination of 8 numbers
Has anyone actually rried to contact bayv ?
post #16 of 22
So then I go to offline acrivation and I get this
Annoying
post #17 of 22
Better pics
post #18 of 22
did you get your tv sorted
post #19 of 22
i have a optica tv with no remote control is there any chance you can give me the model number of your remote so i can try get one did you get your one sorted
post #20 of 22
The only possible way around this is to try and change the firmware on it. as Optica is exclusive to Buy as you view. which is a hire purchase company. what could be the issue is the person you brought this from got it on finance and never paid it of or it could be stolen. which has prompted bayv (buy as you view) to activate the fail safe feature which locks out the tv.
I also believe LG is the manufacturer of Optica. so maybe try using LG firmware?
I hope this helps.
post #21 of 22
Has anybody sorted this problem as I now have the same problem
post #22 of 22
Hi I have just brought this tv does any 1 know if u r able. 2 add anymore apps on 2 it and if so how plz?
