AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Keep cable box's HDMI output on?
post #1 of 5
I have an Optimum Samsung cable box and a PC hooked up to a 27 inch monitor, and I use the monitor's input select to change between them.
My problem seems to be that whenever I use the computer, the cable box thinks the monitor is off so it turns its own output off. Then, if I change inputs to the TV, the monitor doesn't see a signal so it switches back to the PC.
Thus, if I want to watch TV, I have to quickly cycle the cable box and change the input, hoping I get the timing right so they both see each other "on".
Is there any way I can lock the Samsgung's output on all the time like the PC is?
-Robot
post #2 of 5
Don't have the answer for your problem, but have you tried turning the monitor off after switching to cable box, and then turning it back on?
post #3 of 5
How long after switching does the cable box turn off?
post #4 of 5
If it is anywhere and is user accessible, it should be in the settings for the box somewhere. If not, I'd look into getting another box from your provider. My Cisco/SA boxes are always on.
post #5 of 5
My .oxes are also always on.
I would ask for another box.
  Back to Forum: Cable, Digital Cable - Non-HDTV
