AVS › AVS Forum › Audio › Speakers › Polk TSi 300 Vs Pioneer FS52
post #1 of 6
Please state your opinion on which set of 2 of Polk TSi 300 or Pioneer FS52 would be best for
front left and right speakers in a 5.1 system. I got the TSi 300s for $115 each. The FS52s are 125 each at
Best Buy.
I have a Sony STR DN1030 receiver.
post #2 of 6
It is set up in the living room measuring 15x20.
Will be listening to movies mostly and classic rock.
post #3 of 6
Which one did you get? I am kind of interested in this comparison also...
post #4 of 6
Best way to answer your question is take some of your favorite music to Best Buy and listen to both speakers. I'd go with the Pioneers.
post #5 of 6
I would go with the Pioneers rather than the TSi. Unless you go to the RTi / RTiA line then I would go with those.
post #6 of 6
I'd rather get the Monitor 60 or 70's at Newegg. They sound the same and you get more speaker for your money. TSi's sound just like the Monitors they just look different
Currently the Monitor 60's are $99 per speaker they are similar to the TSi400's
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
Monitor 70's are $149 per speaker
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290208
  Back to Forum: Speakers
