AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread
The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 17
post #481 of 2094
I got this one from Best Buy (note, weblink shows Canadian price). This one allows you to connect 3 ethernet cables (eg: receiver, bluray, tv... but note each connection has a different "priority"). It also has a electrical pass thru, which is nice.
http://www.bestbuy.ca/en-CA/product/d-link-d-link-powerline-av500-3-port-hd-media-starter-kit-dhp-p339av-dhp-p339av/10237456.aspx?path=13e51b8ce6ea3751edfe0c2681c55731en02
post #482 of 2094
Originally Posted by lulimet View Post
These are the cheapest on newegg. http://www.newegg.com/Product/Product.aspx?Item=N82E16833704164
Thanks for sharing the links, guys! They all appear to be effective products; decisions, decisions…
post #483 of 2094
Router
Cisco WRT-100
Cisco E3200
Linksys BEFSX41
Netgear N600 3400v2
Netgear WNDR-3800
Netgear WNDR4500
Airport Extreme
Bridge (connected to AVR provides wireless connection to the home's wifi router)
Cisco WRT-54G
TRENDnet TEW-640MB
Airport Extreme
Airport Express
Linksys WET610N
Netgear WN2000RPT - 4 port
Netgear WN2500RP
D-Link DAP-1522
Other
Netgear XAVB5004 Powerline Network Adapter (4-port) (on AVR set Network Standby/IP Control to ON/Always ON)
D-Link Powerline Adapter
Belkin Video Link 3 (w/static IP)
D-Link 8-Port Gigabit Switch (DGS-1008G)
post #484 of 2094
Just FYI: The new Marantz Remote App update (Version 3.1.0 October 23, 2013) is optimized for iPad and iPad mini!!!
post #485 of 2094
Does the 7008 require an external wireless adapter for your router or is it ethernet only?
Edited by Robert Crawford - 10/24/13 at 10:32am
post #486 of 2094
JD what was added if anything on the 7007 vs. the 7008.Thinking about the 7007 as a Christmas present to myself.I can get a 7007 at a really good price.I presently have a Onkyo 805 that is getting a little outdated.If you would pm me a price on either unit. Thanks
post #487 of 2094
D&M models can use a wireless router set up in "Bridge" mode to wirelessly connect to the home's main wifi router.
post #488 of 2094
Is there any way to do all channel stereo on the sr5008
post #489 of 2094
Yes.
Press and hold the Music button. Select "MULTI CH STEREO"
See pages 108 & 113 of the owners manual.
post #490 of 2094
Thank you
post #491 of 2094
Also for anyone looking for the wireless option.
The Asus wireless bridge worked for me.
post #492 of 2094
I have a 5008. I notice that the volume will dip every 20 minutes or so for only a few seconds. I only have it running at 40 as well. Is my marantz defective?
post #493 of 2094
On all sources?
post #494 of 2094
Yeah when using HDMI and through my plex smart tv with optical audio back to receiver
post #495 of 2094
What price have people been able to get the 7008 for (discounted from list)
post #496 of 2094
Send jdsmoothie a PM. He sells Marantz and is an authorized seller.
post #497 of 2094
Guys,
Is there any USB WiFi dongle that will work with our SR-7008?
post #498 of 2094
Although not designed for a WiFi dongle, there was a report awhile back that one did work intermittently, so you can give it a try.
post #499 of 2094
Originally Posted by Louie_18 View Post
Guys,
I used a wireless bridge that connects via ethernet and it worked fine.
I know it isn't a USB dongle. But i just connected it to my laptop so it would connect to my routher then plugged it into the receiver and it is working flawlessly.
post #500 of 2094
Does the SR7008 have any internal fans? Any issues with noise?
post #501 of 2094
Can anyone tell me if the 7008 will show folders and audio files on a network share or DLNA server in alphabetical order (or under what circumstances it shows them out of order)? The manual says it may not, but does have any other helpful information. I'd like to avoid having to use separate HTPC or other device to play music.
post #502 of 2094
I have the 6008 but I don't think the 7008 would be any different. Yes, it shows artist folders in alphabetical order, album folders with the artist folder in alphabetical order. The songs within the album folder are shown in the order that they in the album, not alphabetical.
Now, when I use the Marantz Android app, it shows the songs within the album in alphabetical order.
post #503 of 2094
I would think it depends on how you have the file names. No track numbers and it will sort alphabetically. For instance I use the following naming convention to ensure proper order...
Billy Bragg - Don't Try This At Home - 01 - Accident Waiting To Happen
Billy Bragg - Don't Try This At Home - 02 - Moving The Goal Posts
and so on... no numbers would put them in a different order depending on the song title.
post #504 of 2094
Yes, all my songs titles begin with a number.
post #505 of 2094
Folks,
I am a newbie and just purchased Rotel RMB-1095 and Rotel RMB-1066 recently. I like the Marantz range for their clean look plus quality sound features. With the amps that I already have, do I need a heavy duty AVR like the SR7008? OR will I be OK with the SR 5008/6008 series with the amps that I have bought? Any other options for AVR will be appreciated.
post #506 of 2094
As far as power goes, yes you would be fine. The audio quality of the 7008 would be much superior to the 5008 or 6008.
post #507 of 2094
Thanks lulimet and Hawkboy. I ordered the 7008 from AVS today. Looking forward to hearing it!
post #508 of 2094
Nice! I am sure you will love it. They are great receivers.
post #509 of 2094
Anyone have any comments? Reason I ask is that my current HK flagship AVR from a few years ago started giving me an issue with the video board fan.
post #510 of 2094
I have owned the SR7008 for a month, and have no noise issues Great addition:)
