AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › entire HDD emptied !
post #1 of 8
I have two Philips 3576 and was working both units to try to bring a comatose DVD+R to life. The disc had one long title on it (dubbed from one of the Phillips) with a bit of space left, and I was trying to add a short title to it. I got an Error 3 on both machines. This resulted in the machine freezing at 99% writing to disc, necessitating pulling the plug from the wall in order to restart the machine. I gave up on that disc and successfully dubbed one HDD title to a different DVD on unit #1, finalized the DVD, and put the disc away. I then did some DVD editing & finalizing on unit #2 (no HDD editing), and went back to unit #1, only to find that the entire HDD was blank, showing 199 hours SLP recording time remaining. I recorded a few seconds of dead air and that did create a new title, but none of the previous 65 protected titles were there. I usually shield one unit while controlling the other unit, but this time the shield slipped and I just let it go. So I'm struggling to think what I could have done with the remote while working on unit #2 to cause a total wipeout of unit #1. Or was the damage done via pulling the plug? If so, it was a delayed reaction, since the machine worked perfectly for quite a while, and did not seem to affect the other machine..
I think there's no hope of regaining those deleted titles, but I sure would like to know what went wrong, to prevent it from happening again.
Thanks for your thoughts.
post #2 of 8
Someone else deleted all his HDD titles when he had a 2nd machine accidentally uncovered by unknowingly selecting "HDD Menu" then OK on the uncovered machine, which is right under the "Disc Edit" menu and right above the "Dubbing" menu.
post #3 of 8
That's exactly what happened! The newer Mags have "Delete All Titles" as a 2nd submenu item, but the Phillips has it 1st. So let others beware.
2 questions:
Any way to recover those titles? (not very likely), and
Wajo, I'm glad you saw my post since I didn't mean to start a new thread but to post within our beloved Mag Thread, so is there a way to move this conversation over there for the benefit of our community?
post #4 of 8
2 questions:
People have been working on recovery methods with varied success. Here's my help file on the subject.
Don't worry about starting a new post.
post #5 of 8
Thanks again. I looked at your help file and CDRoller looks promising. Here's what Paul Goldenberg wrote to me:
"CDRoller can assist you to find the deleted video if your recorder has a separate letter in the Windows drives list (Windows Computer). Please check it at first."
So that apply to me?
post #6 of 8
No. The HDD in the recorder is a proprietary format that cannot be mounted by Windows. If you attach it to a PC, Windows will want to reformat it. Unfortunately, your recordings are basically gone. Using low-level tools and a lot of computer skill you might be able to piece together the fragments of a single title in a week. Forget any notion that you might be able to plug the drive into a PC and run recovery tools to get a list of your recordings you could then transfer.
Sorry, but that's really the way it is.
Edited by Kelson - 7/19/13 at 9:25am
post #7 of 8
Well, that's the problem since a normal windows system will not "recognize" a Philips or Mag HDD. It might show up with Linux or a Hex editor (one mentioned in that link I gave). Hex is also mentioned often in this thread on Philips/Mag HDD investigation.
To me, it sounds like a royal PITA to get files off a recorder HDD but might be worth it to retrieve really "precious" memories that can't be re-created?
post #8 of 8
Cr@p! Someplace in the internet I read that a new linux distro could mount "weird" drive formats (Native HEX capabilities in the OS for the new android and other tablets) I need to find that info again. eek.gif
  Back to Forum: DVD Recorders (Standard Def)
