AVS › AVS Forum › Audio › Audio theory, Setup and Chat › REW EQ + miniDSP discussion
post #1 of 9
It was suggested in the REW Setup thread that I start a new thread to discuss the use of REW's EQ feature with the miniDSP, so here it is! biggrin.gif
I'm a complete newby to REW and sub EQ. About a month or so ago I downloaded REW and started learning to take measurements. Now that I'm more comfortable taking measurements and have gone as far as I can with sub placement and bass management tweaks (room treatments aren't an option in my living room ), I'd like to give PEQ a shot.
Later this month I plan to order a miniDSP and have been asking questions about how REW EQ and miniDSP work together so I'll be a bit prepared when I get the miniDSP. Once I get started I plan to post graphs here and hopefully get feedback from other REW EQ/miniDSP owners on how to proceed. smile.gif
Discuss away!
post #2 of 9
From the other thread:
Originally Posted by Saturn94 View Post
Originally Posted by amirm View Post
It is not clear you want to use AutoEQ anyway. The best use of EQ is to take one or two of your massive peaks post REW measurement, and pull them down with a couple of filters.. The precise curve fitting that REW performs may or may not sound good. Whereas the couple of filters most likely will. So don't worry about whether REW supports the automatic programming of the filters. Measure your low frequency response using REW as documented, find the peak value and guess at the rest of the parameters like bandwidth/Q. You will have to iterate a bit to get the curve which is a good exercise anyway to learn what the filter does audibly and in subsequent measurement using REW.
I figured since I'm not sure what kind of curve I would like, I could use REW's auto EQ to get an idea what different curves sound like, then start manually tweaking once I narrowed my preferences down a bit. Hopefully I'll learn a bit in the process. wink.gif
Before you use REW's auto EQ to get an idea what different curves sound like, follow Amir's advice and knock down the biggest couple of peaks in the frequency response.
To guage your preference, rather than designing and loading different target curves, just play with the bass and treble controls on your receiver. It will be a much quicker way to find out which direction your tastes lean towards (a little more bass, a bit less in the highs), so that you can narrow down the range of possible target curves to ones that are within your preference.
post #3 of 9
I do know I don't like a flat response. Some time ago I tried SVS's auto sub EQ unit (made by Audyssey). It would only EQ flat with no other options. Didn't like it, returned it. wink.gif
post #4 of 9
Count me in as part of this thread. I'm a video calibrator and just recently got interested in audio. I've been learning REW and presently have a miniDSP 2x4 on order. My mic is a UMIK-1 and I have the Advanced 21 Plugin.
post #5 of 9
I need to figure how to use a MiniDSP better. I have one that I am not currently using, I have an SMS-1 that I am using now with one sub, HsuVTF-15H. I am going to start a DIY pair of subs when the weather cools. I will need to be able to adjust two subs seperately. When I got the MiniDSP I used it with a legacy REWset up and an old computer I had. The computer crapped out. I will be getting a USB mike to use with a laptop.
post #6 of 9
http://www.studiomanuals.com/docs/rane/rane_pe17_manual.pdf
Seriously though, bassheads been messing around with the mini. Maybe he will chime in.
post #7 of 9
I've been doing a number of measurements and have found that there's an issue with bass response from my right front speaker. I've done the best I can to get the best response by tweaking the bass management settings, but it still needs help.
Can I use two of the outputs on the miniDSP (2x4?) to EQ a pair of subs and the other two outputs to EQ the bass on the left and right speakers?
Perhaps I should post this question in a miniDSP thread?
post #8 of 9
This thread is way too quiet. I have been waiting for you guys to start eq-ing your multiple subs with your minidsp's to see what MY next step is!
OK, I have 2 SVS subs, a PC12 and a PB1000 f3's of 20Hz) 1/4 and 3/4 on my front wall in my 20x15x9 (w x l x h) living room. I have a third Yamaha sub (f3 of 30Hz) on my side wall.
My plan was to use the minidsp to get the 3rd sub distance correct (using the minidsp delay), then run audyssey, then do crossover sub distance tweak. I have a Onkyo818 so all sub eq is combined, hence the minidsp. I am using one input, with 3 outs to each sub.
anyone got any other/better ideas for me?
thanks
post #9 of 9
thanks
Yes, too quite.
I was hoping to have a miniDSP by now, but I got sidetracked. Also, instead of getting multiple subs, I decided to go with a single sub (PSA Triax) for now since I already get a good response from my current sub location.
Your idea seems right, but unfortunately I don't have any room correction software such as Audyssey so I'm not sure what order you would do things.
