AVS › AVS Forum › HDTV › HDTV Recorders › Homeworx HW-150PVR, Support and Discussion
Homeworx HW-150PVR, Support and Discussion - Page 29
post #841 of 1229
Originally Posted by JHBrandt View Post
Originally Posted by seattlemark View Post
I plan on using two HW-150s in series, using the RF out (with "Loop through" Modulation setting) of the first unit sending the antenna signal to the second unit. (So no splitter necessary for this.) That way I can record back-to-back TV programs (even on different channels), without losing any of the second program's recording. (Which can happen with just one unit when it's switching to recording mode for the second program.) With two units, both units can be programmed to record their shows a bit early, and end a bit late, without a problem. So I will basically have a two tuner DVR setup (like I had with the cable company I cut the cord from). Since my TV has multiple Component and HDMI inputs, I won't even have to move cables to watch either recording; I will just need to switch inputs on the TV.
Have you thought about how you're going to control them separately, since they both use the same remote? (One solution would be to load iView firmware on one and buy an iView remote.)
Note: In the past I've repeated a suggestion which I read somewhere, but which I recently discovered will not usually work: using polarized filters over the remote's IR LED and each box's IR sensor, and rotating the remote to control one unit or the other. The problem is most polarized filters work only over the visible frequency spectrum ant not at IR (not even near IR) frequencies. There are near-IR polarized filters (for photographers), but they are very expensive.
You need a KLUGE!
Explanation here.
post #842 of 1229
Originally Posted by Thxtheater View Post
Anyone here using the homeworx coax digital audio out? I just got a replacement unit and I still cannot get digital audio via COAX. audio over HDMI is fine. I have tried PCM, RAW, and RAW HDMI with no luck. I have also disconnected the HDMI cable. My Anthem says there is no digital input.
I tested the cable on an Oppo and it works just fine and I tested it on the same input port.
I'm at a loss as to why I can't get audio via digital coax??
Haven't used it myself, but at least one person seems to be having success with coaxial digital audio:
Originally Posted by oldspammer View Post
Seems to me from my experimentation of feeding the HDMI output to a computer capture card and having the digital audio coax go to my 5.1 audio receiver, the only audio mode that delivered Dolby digital AC3 to the audio receiver was the setting designated "PCM" in the menus--a non-obvious setting.  Other settings changed the recognition done by my receiver as "non-5.1" audio.
post #843 of 1229
You need a KLUGE!
Explanation here.
Clever ideas. #4 is obviously specific to the Funai HDD/DVD recorders, but the other 3 would work for the Homeworx.
Cleverest, although the most expensive, is the idea of using two NextGen remote extenders, one at 418 MHz and the other at 433 MHz. Of course you'd have to seal each "flying saucer" and its corresponding Homeworx in separate light-tight boxes (perhaps with holes for cables/ventilation in the back). Although NextGen extenders are rather expensive for this use, they're still cheaper than near-IR polarized filters - and you'd get the advantage of whole-house control!
post #844 of 1229
I'm getting audio to my surround sound unit from the HW-150 thru the coax, not sure it is multi-channel. Haven't messed with it too much yet, just swapped it into it's current location, where I used to have an iview-3500.
Are you getting no sound at all? Or just not 5.1? Is this from live TV, or playing back recorded programs?
I'll play around with it and see what I get.
post #845 of 1229
Have you thought about how you're going to control them separately, since they both use the same remote? ...
Yes, I am going to keep it rather simple. When setting up two recordings, for the first recording I plan to temporarily turn off the other HW-150 that I don't want the remote to affect (by using the physical button in the front of the unit). Then doing the opposite to set up the recording on the other unit. (I tested something similar before with a remote as I already own two units, that are normally in two rooms, but were together for that test.) For playback, even if I keep both units on at the same time it would be okay as I have separate Component or HDMI cables going to separate TV inputs. But I need to also look closer at the KLUGE wajo is referring to above!
In actuality most of the time I will be needing just one unit for my recordings, but for the price it was worth getting a second unit for the main TV. As occasionally over the last month I have wished I had one. (Like when I recently messed up my wife's TV viewing on that TV because of my recording. smile.gif )
Edited by seattlemark - 1/15/14 at 1:55am
post #846 of 1229
You can also use a solution based on iTach devices that have discreet IR ports. So you can control the same manufacturer or same model devices independently. I use Roomie Remote org iTach IP to IR converters and use both the supplied flashers and the Niles IR flashers. It works flawlessly.
post #847 of 1229
Tested my HW-150 coax digital out. Results: 5.1 digital works in the RAW as well as the RAW HDMI ON settings. DOES NOT WORK when set to PCM. (Stereo only)
Only tested the coax digital output, my surround amp doesn't have HDMI inputs. (RCA RT-2350 circa early 2000's)
Works this way with live TV or recorded shows.
SW Version: CL630133 131115 V14
HW Version: 7816-ATSC-03
post #848 of 1229
Ok, this is really helpful and I appreciate your help on this. I have it set to HDMI Raw but no audio. Can I ask what other connections you have on the unit?
Right now, I'm just trying to confirm live TV. I'll deal with recorded stuff later!! smile.gif
Thanks a ton for this.
post #849 of 1229
Just to confirm, I'm getting no sound at all from the digital coax output. I get sound from RF and HDMI just fine. I haven't tested the analog outputs yet.
post #850 of 1229
Connections on the HW-150, or surround amp?
HW-150: Sending component video and analog audio to TV via RCA cables. Coax Digital to surround amp. Antenna in F connector, ch3 out via F connector thru 30' coax cable to old TV in kitchen.
post #851 of 1229
What are your Hardware/Firmware versions? Sounds like it might be a firmware issue.
post #852 of 1229
At least your antenna is up high. That's a good start; it'll keep your signals from being affected by blowing tree limbs.
I couldn't find a noise figure for the Philips amp. That's usually not good news.
I bet you'd have the best results by removing the Philips amp and passive splitter, and replacing the combo with the CM distribution amp. Signal strength will be slightly lower (so you probably won't need an attenuator) but the noise will probably be a lot lower (the first amp's NF usually completely dominates anything downstream), so the S/N ratio will probably improve. That should help.
Thanks JH and Chaz I'll give the CM a try and if it doesn't work after 2 weeks I'll send it back to amazon. I also read if it's windy outside breakup tends to happen. I wish they had a HDMI type of coaxial to get the best picture ever.eek.gif
post #853 of 1229
I
I'll double check that after work tonight. The units are brand new from Amazon but who knows how long they have been sitting in inventory!
post #854 of 1229
Yep I can confirm that via coaxial on my receiver(AUX) is Dolby Digital 5.1.
post #855 of 1229
Hello,
 I recently purchased an HW-150 PVR and I'm starting to realize it wasn't the solution to my problems.
I'm looking for a device that will output all the channels my TV can receive through coax, except in HDMI. (For use with the Xbox One)
I feel like this crap diagram can explain it better than I can in words.
I'm starting to think the only thing that will do this for me is renting a cable set top box from Cox (my provider)
If there is an alternative please let me know. And if you could educate me on why the HW-150 PVR didn't do the trick, and the differences between QAM, Clear QAM, ATSC, OTA, and all that nonsense I would appreciate it.
post #856 of 1229
Wow! My SW version is v8??!!! Specifically build CL630133 130713 V8. Hardware is identical to yours. It looks like the Amazon stock is a bit outdated! I'll upgrade firmware and report back.
post #857 of 1229
Well, now the mystery deepens. Per the Homeworx forum: http://forum.mediasonic.ca/viewtopic.php?f=44&t=1925&sid=dd818c13dd8c23238c5464b76dc7ba0e
Stop chasing for firmware update ( there is no update)
if you box came with
V8 is the latest for your unit
V13 is the latest for your unit
V14 is the latest for your unit
V1 is the latest for your Unit
all the above have the same fix as V10 (the only major fix we released)
if there any firmware update we will announce it
Hmm.. Now I need to pursue more info on this problem with no audio via coax.
post #858 of 1229
Mine came with V14, but I upgraded to the "QAM V14" that you have to request from them. Seems very stable. I don't use QAM, just wanted to test my cable line, as I only get phone and internet. Even so, I get clear QAM, and get the major (broadcast) networks in HD, but no sideband channels, and no PBS. So pretty worthless.
When I get my new HW-150 in a few days, I'll check the firmware. My present one had SW: CL630133 130925 v14.
post #859 of 1229
Originally Posted by bgb27 View Post
Hello,
OK, I think I see what you're saying. You have cable, and you wanted a cable tuner with an HDMI output to route through your XBox. I assume you loaded QAM firmware onto your Homeworx so you get Cox's clear QAM channels.
The big question is, which channels does your TV get that the Homeworx doesn't get? There are two possibilities:
  1. Encrypted channels (which implies your TV is one of the few that uses a CableCARD). If this is the case, you'd need a CableCARD tuner. Among DVRs, your only hope is TiVo, or a PC with a Ceton or HDHomeRun Prime tuner.
  2. Analog channels. if this is the case, you need an analog tuner with an A/D converter and HDMI output. The PHD-VRX2 would do the job and let you tune analog channels (although it will only record digital ones). If you don't need the ability to record, I believe the PHD-208 will do the job for somewhat less.
One thing to watch out for: with either the Homeworx or the PHD products, the XBox's OneGuide may not work as you expect with cable. Reason is, these boxes show physical (RF) channel and subchannel numbers while the OneGuide shows virtual channel numbers. That means the XBox won't be able to tune your Homeworx or PHD product to the proper channel when you pick a show from the OneGuide. (Tuning analog channels on the PHD products would work, since there are no virtual channel numbers for analog, but tuning digital channels wouldn't work.)
CableCARD tuners such as TiVo or PC tuners won't have this problem since they can pick up Cox's channel map table.
Edited by JHBrandt - 1/15/14 at 4:17pm
post #860 of 1229
Well, now the mystery deepens. Snip. Hmm.. Now I need to pursue more info on this problem with no audio via coax.
Maybe send them a request for QAM enabled firmware, and the fix will be included in that version? They got back to me within hours when I requested it. At the least, if you have a new working Firmware file, you can maybe play with V14 that some kind soul will send you. That way, if V14 breaks something, you can go back to the version they send you.
Wish they had a way to back up the firmware that is on the unit.
post #861 of 1229
Thank you.
I would have to believe it'd be the analog channels. I really only care about ESPN, ESPN2, etc. which are channels I did not receive. Would it be safe to assume those are analog?
My HW-150 PVR did pick up 400 channels, but only one was viewable.
Also, if anyone was looking to give this HW-150 PVR a new loving home, I did post it on amazon under new for 35.99 which is what I paid.
Edited by bgb27 - 1/15/14 at 5:02pm
post #862 of 1229
Yes; if they are viewable on your TV without any equipment from Cox (cable set-top box, CableCARD, etc.), but not viewable on the Homeworx, they are most likely analog. If they're viewable on older TVs (the kind with picture tubes instead of flat-panel displays), they are almost certainly analog.
Unfortunately the Homeworx channel scan picks up encrypted as well as clear QAM channels. Apparently you have only one clear QAM channel, making the Homeworx pretty useless for your cable system frown.gif
I suggested the PHD products because they will tune both analog and clear QAM, like a typical TV. But since you have only one clear QAM channel, there may be cheaper analog-only tuners with HDMI outputs that would work just as well.
I'm guessing the one that worked was a "barker" channel telling you that you need a cable box or CableCARD to view encrypted channels. If so, you might want to leave a post here to let others know what your Cox branch has done:
http://www.avsforum.com/t/1475637/are-all-your-qam-channels-scrambled/0_20
post #863 of 1229
After they got more in stock at NewEgg today, I also bought another this afternoon. .....
Chazdole, in addition to today I previously bought two of these from NewEgg a month ago, and the free shipping was great. I received them very fast in prefect shape.
Cool, that's good to hear. I ordered a Shawshank bluray for $6 something and free shipping from WB Shop, a big company, on Dec. 24th. They still haven't shipped. ...
My new one came already today. Very impressive once again about the service and the FREE shipping on this particular unit from Newegg. I ordered this HW150PVR unit the afternoon of Jan. 13th, and it just came the afternoon of Jan 15th. I am two states away from Newegg. (Newegg is in Southern California, and I am in Seattle, Washington area. Newegg uses OnTrac for shipping between certain nearby states to them.)
As of this time Newegg still shows them in stock, and their $10 off Promo coupon goes through tomorrow Jan. 16th (which is on top of their sale price).
Edited by seattlemark - 1/15/14 at 5:22pm
post #864 of 1229
According to the Homeworx forum there is no difference in the firmware between v8, v10, v14. Not sure what or how but they say v8 is the current build.
post #865 of 1229
Great! That's fast. I also ordered mine on the 13th, 2pm. Fedex tracking now shows it in the south side of my city, as of 7pm. Came from Memphis, I'm in Ohio. Pretty fast for free. The free shipping says 4-7 business days, I didn't expect it till next week. Looks like tomorrow or Friday. Yippee!
I'm gonna leave this one stock if it has the V14 firmware.
post #866 of 1229
That does seem odd, doesn't it? One way to find out. Does your unit do QAM? I thought none of them did while stock firmware was installed? Only after requesting new firmware and flashing would QAM work, AFAIK.
I'll test my stock unit when it gets here tomorrow or Friday.
post #867 of 1229
My new one came from Newegg today, Jan 15th, and it has V13. The two I received from Newegg middle of Dec. both had V14. I don't know what the difference is, if any, between V13 and V14. (If someone can tell me, please do so.)
post #868 of 1229
They have a series of FAQs on their support forums on the topic of the firmware. Read here as they are quite emphatic that all the firmware versions are the same: http://forum.mediasonic.ca/viewtopic.php?f=44&t=1925&sid=2f8a9819f4dd44bbdca67586685a4ed1
v.8, v13, v14 are all identical except for the logo on boot up. They go into it all in case anyone has any questions.
In my case on box has v8 and the other must have v13 or 14 as one box has the logo and the second does not.
post #869 of 1229
Try emailing rma_east@mediasonic.ca and request firmware to enable QAM, if you don't have that capability.
I know they are implying that all these versions are the same, but then why do they offer upgrade firmware to enable QAM?
post #870 of 1229
v14 boxes have a new chip in them but they wouldn't say which chip. If you are so inclined you could open up your boxes and look for the difference.
  Back to Forum: HDTV Recorders
