AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Spindle rubber for CLD 2950
post #1 of 7
Hi All
I'm in the UK and looking for the spindle rubber for a CLD 2950.The Pioneer part number is VEB1135.
If anyone knows where I can get one I would be very gratefull.
Also does the above VEB1135 also fit the CLDD925 and the CLD D703?
Thanks for any help
Smiffy
post #2 of 7
Are you sure of the part number. The 2950 looks like a CLD-D503 and the spindle motor rubber cushion for that is VEB1237. Pioneer in the US says VEB1135 is no longer available.
post #3 of 7
Yep
Got service manual here.Def VEB1135.I'll give VEB 1237 a go then.ta
App not replaceable in the D925.You have to get the whole spindle.And don't have service manual for CLD D703 to check that part number
Thanks for the help
John
post #4 of 7
The VEB1237 is the part for the 503/703/704/79/99
post #5 of 7
Thanks Kurtis
I will take the top off the CLD D703 and compare it to the CLD 2950.
I dont think the CLD D925 is replaceable.I think you have to replace the turntablke spindle.
This appears to be pt number VXA2225 but states in manual NSP which I presume means non service part
Smiffy
post #6 of 7
Checked the CLD 703
The CLD 703 and 2950 use the same spindle assembly so I guess VEB1237 will fit both
Just having trouble finding the part in the UK
Smiffy
post #7 of 7
I can always buy some for you in the US but they are not cheap, with tax and shipping they are around $20 each. Then add shipping to you
  Back to Forum: DVD Players (Standard Def)
