AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › CoolGeek's Concrete Bunker Home Theater Build
CoolGeek's Concrete Bunker Home Theater Build - Page 4
post #91 of 99
Most screens mount with a French cleat system and gravity. If you need to access the speakers you pick it up and set it aside.
In my case the fabric panel below the screen is also removable most of what I need to get to is accessible via that as a service hatch.
post #92 of 99
+1
post #93 of 99
What Big said is what I do as well, but I have also seen people use piano hinges and lift the screen up. Then they place a prop bar or something to hold it up.
post #94 of 99
I kinda of like JapanDave's model. His can be opened up like a door, swing sideways.. not sure how exacly he implemented it, hinges, magnets, etc???
post #95 of 99
Another vote for french cleat. I changed mine from store bought cleat/hangers to a french cleat I made myself from 1x6. DIY was much better and cheaper and very easy to do
post #96 of 99
Can someone tell me what a french cleat is n where to buy it? Are there pics?
post #97 of 99
Google Z clips, they come from various vendors and in various lengths, Home Depot has them. IKEA has used them to hang kitchen cabinets. You can make one from pieces of wood cutting an angle on both pieces.
Pictures and Video here
http://www.eagle-aluminum.com/Eagle-Z-Clip_ep_42.html
post #98 of 99
Ah. Thanks. This looks like a plan
post #99 of 99
All the cables going thru my basement
