AVS › AVS Forum › 3D Central › 3D Tech Talk › Watch Youtube 3D videos on 3DTV
post #1 of 2
Hi. How do I enable 3D youtube videos for my Panasonic Viera TX-P50UT50Y? How does it work, can i just plug in my compuiter to the tv via HDMI and play the youtube video and the tv will detect that It's 3D?
What kind of settings should I choose on Youtube to make it work?
THank you in advance!
post #2 of 2
One way that is pretty universal is to select SBS half in YOUTUBE player on your computer running windows, then select SBS Half on your TV. Your computer video card will need to support the minimum resolution required by the TV for 3D display, likely 1080 x 1920. Since it's SBS half, it doesn't need to be a 3D Video card.
Some 3DTV's use widigts you can launch. My older Vizio 32" just got an update to it's YouTube widgit that now recognizes YT 3D content automatically. I can set channels on YT that are from friends who do 3D as well as my own channel. Now when I launch that widgit, and select a channel in 3D the 3D plays automatically.
  Back to Forum: 3D Tech Talk
