AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic TX-P42G20B Power Problem
post #1 of 3
Hi,
I have a problem with my Panasonic Plasma TX-P42G20B TV which I hope somebody can advise me on?
The TV switches itself off and then the green led flashes 3 times and clicks 3 times as though you are trying to switch it on with the remote, it continues to do this repeatedly until you switch off at the mains, if you leave the TV off for a few hours it comes on again for about half an hour then switches itself off again repeating the same problem.
Would really appreciate some help with this
Thanks in anticipation.
post #2 of 3
3 blinks is typically A or D board. PM me and I may be able to send you service documentation to help you fix it.
post #3 of 3
Hi, Tom, maybe You know how to fix my Plasma TX-P42G20B ? it,s shows vertical bar in centre tv
http://www.1x2.talktalk.net/l3.jpg
