AVS › AVS Forum › Audio › Speakers › Bose Cinemate GSII Wall Mounts, UB-2
post #1 of 5
I picked up a couple wall mounts online for a Cinemate GSII, I received the Bose UB-2 Mounts, it looks like these are the wrong ones. I don't have the Cinemate here to just try, can anyone tell me if these mounts will work with the Cinemate GSII? Thanks
post #2 of 5
Yes they should work just fine.
post #3 of 5
Thanks, I thought they might, but I couldn't find anywhere that said it would.
post #4 of 5
Thanks again, they worked great:
post #5 of 5
Good! Glad it worked out for you.
  Back to Forum: Speakers
