AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Least expensive Bluetooth and WiFi capable AV receiver?
post #1 of 7
Title says it all. Any advice/suggestions would be much appreciated.
post #2 of 7
I think Sony makes a wifi and bluetooth capable receiver. Either the 840 or 1040.
http://www.crutchfield.com/S-40Fne9YhxVv/p_158STN1040/Sony-STR-DN1040.html
http://www.crutchfield.com/p_158STDN840/Sony-STR-DN840.html?tp=179
I don't know how well it works or sounds, not interested in either one of those features. Just providing links to a couple of products to get you started.
post #3 of 7
Are you needing these features built in, or just accessible with peripherals?
post #4 of 7
Honestly, whichever would be the cheapest option.
1) Built in OR
2) Not built in + extra peripherals
post #5 of 7
Anyone?
Beuler......Beuler.....Beuler....
post #6 of 7
Those are your only options for WiFI and Bluetooth built in. Any AV receiver with Ethernet can be connected to your home WiFi network using a generic wireless bridge that you can usually get cheaper than any manufacturer's own bridge. Bluetooth would more or less require that you use the manufacturer's own Bluetooth add-on, but this isn't as useful as you might think.
post #7 of 7
Onkyo's latest TX-NR series.
Patrick
