AVS › AVS Forum › Video Components › Home Theater Computers › Can't seem to get 5.1 - PC->HDMI->TV->Toslink->Amp
post #1 of 17
My setup is as follows: PC->HDMI->TV->Toslink->Amp
When I plug in my PS3 via the same method, 5.1 passes through just fine. Anyone have an idea how I can get my PC to work in the same way?
Graphics Card (Click to show)
EVGA GeForce GTX 660 (SC)
TV INFO (Click to show)
Monitor
Model name............... SONY TV
Manufacturer............. Sony
Plug and Play ID......... SNYEA01
Serial number............ n/a
Manufacture date......... 2010, ISO week 1
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 1600 x 900 mm (72.3 in)
Power management......... Not supported
Extension blocs.......... 1 (CEA-EXT)
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.635 - Ry 0.336
Green chromaticity....... Gx 0.285 - Gy 0.608
Blue chromaticity........ Bx 0.146 - By 0.061
White point (default).... Wx 0.280 - Wy 0.290
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 15-70kHz
Vertical scan range...... 58-62Hz
Video bandwidth.......... 150MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz (16:9)
Modeline............... "1920x1080" 148.500 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
Detailed timing #1....... 1280x720p at 60Hz (16:9)
Modeline............... "1280x720" 74.250 1280 1390 1430 1650 720 725 730 750 +hsync +vsync
Standard timings supported
640 x 480p at 60Hz - IBM VGA
800 x 600p at 60Hz - VESA
1024 x 768p at 60Hz - VESA
1280 x 1024p at 60Hz - VESA STD
EIA/CEA-861 Information
Revision number.......... 3
IT underscan............. Not supported
Basic audio.............. Supported
YCbCr 4:4:4.............. Supported
YCbCr 4:2:2.............. Supported
Native formats........... 0
Detailed timing #1....... 1920x1080i at 60Hz (16:9)
Modeline............... "1920x1080" 74.250 1920 2008 2052 2200 1080 1084 1094 1124 interlace +hsync +vsync
Detailed timing #2....... 720x480p at 60Hz (16:9)
Modeline............... "720x480" 27.000 720 736 798 858 480 489 495 525 -hsync -vsync
Detailed timing #3....... 720x480p at 60Hz (4:3)
Detailed timing #4....... 1440x480i at 60Hz (4:3)
Modeline............... "1440x480" 27.000 1440 1478 1602 1716 480 488 494 524 interlace -hsync -vsync
CE video identifiers (VICs) - timing/formats supported
1920 x 1080p at 60Hz - HDTV (16:9, 1:1)
1280 x 720p at 60Hz - HDTV (16:9, 1:1)
1920 x 1080i at 60Hz - HDTV (16:9, 1:1)
720 x 480p at 60Hz - EDTV (16:9, 32:27)
720 x 480p at 60Hz - EDTV (4:3, 8:9)
720 x 480i at 60Hz - Doublescan (16:9, 32:27)
720 x 480i at 60Hz - Doublescan (4:3, 8:9)
1920 x 1080p at 24Hz - HDTV (16:9, 1:1)
640 x 480p at 60Hz - Default (4:3, 1:1)
NB: NTSC refresh rate = (Hz*1000)/1001
CE audio data (formats supported)
LPCM 2-channel, 16/20/24 bit depths at 32/44/48 kHz
AC-3 6-channel, 640k max. bit rate at 32/44/48 kHz
CE speaker allocation data
Channel configuration.... 2.0
Front left/right......... Yes
Front LFE................ No
Front center............. No
Rear left/right.......... No
Rear center.............. No
Front left/right center.. No
Rear left/right center... No
Rear LFE................. No
CE vendor specific data (VSDB)
IEEE registration number. 0x000C03
CEC physical address..... 1.0.0.0
Supports AI (ACP, ISRC).. Yes
Supports 48bpp........... No
Supports 36bpp........... No
Supports 30bpp........... No
Supports YCbCr 4:4:4..... No
Supports dual-link DVI... No
Maximum TMDS clock....... 150MHz
Audio/video latency (p).. n/a
Audio/video latency (i).. n/a
HDMI video capabilities.. No
Data payload............. 030C001000801E0F
Report information
Date generated........... 7/26/2013
Software revision........ 2.70.0.989
Data source.............. Real-time 0x0071
Operating system......... 6.2.9200.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,D9,01,EA,01,01,01,01,01,14,01,03,80,A0,5A,78,0A,83,AD,A2,56,49,9B,25,
0F,47,4A,21,08,00,81,80,01,01,01,01,01,01,01,01,01,01,01,01,01,01,02,3A,80,18,71,38,2D,40,58,2C,
45,00,40,84,63,00,00,1E,01,1D,00,72,51,D0,1E,20,6E,28,55,00,40,84,63,00,00,1E,00,00,00,FD,00,3A,
3E,0F,46,0F,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,4F,4E,59,20,54,56,0A,20,20,20,20,20,01,5F,
02,03,22,70,49,10,04,05,03,02,07,06,20,01,26,09,07,07,15,07,50,83,01,00,00,68,03,0C,00,10,00,80,
1E,0F,01,1D,80,18,71,1C,16,20,58,2C,25,00,40,84,63,00,00,9E,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,
40,84,63,00,00,18,8C,0A,D0,8A,20,E0,2D,10,10,3E,96,00,B0,84,43,00,00,18,8C,0A,A0,14,51,F0,16,00,
26,7C,43,00,B0,84,43,00,00,98,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,07
I've searched for hours for a solution, so any help would be appreciated.
post #2 of 17
What media player are you using?
post #3 of 17
Thanks for the reply. I know how to get 5.1 while watching a movie through my media player(Media Player Classic/CCCP) (despite it still only being set to stereo in my speaker config). I'm mainly looking to be able to select 5.1 in my speaker configuration via Windows, so then I'll be able to get surround sound while gaming on my PC. Any ideas?
post #4 of 17
PC games use multichannel pcm for audio. SPDIF only supports 2ch pcm.
post #5 of 17
So if I understand what you're saying, then it's only possible to have surround sound in games via HDMI? You're saying that even if I bought a sound card with a digital optical out, then 5.1 wouldn't work in games?
That doesn't sound right to me, so please explain if you're able to.
I was thinking it's an issue with my PC detecting the TV as 2 channel and not passing through to the 5.1 amp. There's no way available to manually setup my speaker configuration (like PS3 and Xbox allow)?
post #6 of 17
I don't understand why your setup isn't PC -> Amp -> TV, all HDMI, no Toslink.
post #7 of 17
You have three choices to output multichannel audio in PC games...
  1. Output HDMI from the GPU into the receiver. The receiver and GPU must support HD AUDIO or at least Multi Ch PCM.
  2. Buy a sound card that supports Dolby Digital Live or DTS Interactive. This will convert Multi Ch PCM to Dolby Digital or DTS which SPDIF can passthrough. HDMI would go into the TV and SPDIF into the receiver.
  3. Use the audio outputs from your sound card using three 3.5mm to rca jacks. This will connect to the multi ch input on your receiver.
post #8 of 17
Well to complicate matters, I recently bought a 5.1 capable headset, so the only way I can configure it so that it would work with all my systems as well is through the setup I mentioned.
Which is essentially: PS3/PC/Xbox -> HDMI -> TV -> Toslink -> Headset AMP -> Toslink -> AMP
This currently works for my other 2 systems, just not my PC...
This would all be solved if my AMP had a Toslink output so then I could just run everything through there and then out into my headset amp, but unfortunately it has no such output...
I understand now. Guess I'll probably be going with option 2. Thanks for the help.
post #9 of 17
I'll wager it's your TV. Many TVs will forcibly downgrade the digital audio output to 2.0 channels when fed from an HDMI source, even though they happily output 5.1 when fed from their own ATSC/QAM tuner.
It sounds mind bogglingly stupid, but it's true. There are a few threads scattered around all the forums here complaining about it. You won't be able to solve this problem by fiddling the audio settings on your PC. You need to change to Source->AVR->TV. If you don't have or want an AVR capable of this, you can get an EDID-aware HDMI audio extractor and put it upstream of the TV.
Edited by EricN - 7/26/13 at 2:46pm
post #10 of 17
That's my first impression as well. But how do you explain that OP's PS3 works fine?
post #11 of 17
Sounds like a hdmi splitter should get it done. You'd be running hdmi to both the avr and the tv. I don't have first hand experience with one but I can't imagine it not working. That's assuming your avr has hdmi input, if not check here..
http://www.avsforum.com/t/1215060/hdmi-to-toslink-splitter
post #12 of 17
post #13 of 17
Does the PS3 ignore the display's EDID when 5.1 output is explicitly selected?
Regarding the hdmi splitter or the hdmi->toslink audio extractor, this may not solve the problem if the TV is claiming that it will only accept 2.0 audio over hdmi. If that is the case, you'll need some way to override the EDID
post #14 of 17
If i understand the op correctly, pc gaming is the issue and that's kind of the point of a HDMI splitter..both the TV and avr would be receiving the HDMI signal from the PC.
post #15 of 17
Even when I don't set it "Manually" on the PS3 and just select "Automatic" in the sound settings, my PS3 incdludes Dolby Digital 5.1 in the setup. Not sure if it's detecting it, but that's what I'd assume. Dolby 5.1 plays perfectly in games, movies, etc..
But if what my understanding of what Mrkazador said is correct, then that's because my PS3 supports Dobly Digital Live and my GTX 660 only supports Dolby Digital. You would think a $200+ graphics card would support such a thing...
Well, my AMP has an HDMI output. So what I was doing before was: PC->HDMI->AMP->HDMI->TV
Which worked just fine, 5.1 and all. But If you read one of my previous post, you can see why I need to set it up the way I mentioned:
post #16 of 17
The reason consoles can output games in multichannel is because the audio is being output as Dolby Digital. Having Dolby digital live on the GPU would be a useless feature, maybe one out of 100000 people would use it.
Most TVs don't output 5.1 from the optical port when using HDMI. Do you know for sure its outputting 5.1 and not 2.0???
post #17 of 17
Yes, I'm sure. At the XMB on PS3 it's 2 channel, but when I start a game or movie which has 5.1 audio, I can see the speakers become active on my amp. I've played many games and watched many movies on my PS3 and XBOX 360 with this setup and it's apparent the 5.1 surround works perfectly. Which is why I'm dumbfounded that my GPU doesn't work in the same way.
In case it may be relevant.... My AV reciever: http://esupport.sony.com/US/p/model-home.pl?mdl=STRKS360S&LOC=3#/howtoTab
