AVS › AVS Forum › Audio › Speakers › subwoofers; are two better than one
post #1 of 7
are two subwoofers better than one? is it better to have two smaller inexpensive units than one large unit?
post #2 of 7
Two subs are better than one sub, because you can smooth out the bass response in the room better. Hard to say if two cheaper subs are better than one more expensive sub, because we could be talking about anything. In other words two $100 subs are not going to be better than one $1,000 sub. Just using money as an example.
post #3 of 7
great point..lets say 2 600 dollar 10 inch vs 1 1000 12 inch..maybe an episode or force five from goldenear
post #4 of 7
Two of these SVS SB-1000 would be great for a medium sized listening area.
http://www.svsound.com/subwoofers/sealed-box/sb-1000#.UfLd9hy2tvk
How large (cu ft) is your home theater/listening area? Also you might post your question in
the sub forum.
I don't know to much about the subs you are referring to.
vardo
post #5 of 7
Shouldn't this be in the subwoofer part of the forum and not in speakers?
post #6 of 7
Yes
post #7 of 7
great will do that..did not notice a subwoofer forum thanks
  Back to Forum: Speakers
