post #91 of 91
Another issue you have to consider that Im currently experiencing is that NOT all motherboards are compatible with CETON InfiniTV and Windows. You have to make sure your motherboard works with Media Center due to how it activates which is tied to the motherboard.
If you build a HTPC, make sure the motherboard works with both Windows and digital media.
