AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Ceiling box covers with speaker posts
post #1 of 6
I have a new house that has the rear speakers wires running to ceiling boxes. I will be running bookshelf speakers attached to the ceiling.
I want a cover plate for the ceiling box with speaker binding posts, but have not found one yet.
Any recommendations?
Thanks in advance.
Paul
post #2 of 6
Check out Leviton products.
Look here:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=39143&minisite=10251
These types of inserts along with the two-port cover plates can be found in your local big box store.
post #3 of 6
post #4 of 6
Thanks for the replies.
The ceiling box is round rather than the rectangular switch box those products are for.
Paul
post #5 of 6
I don't know of any premade round covers with speaker binding posts. It might be that you'll have to "roll your own".
Start with this:
http://www.lowes.com/pd_163859-223-CPC4WH_4294653953__?productId=3127885&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=
Drill two appropriate spaced and sized holes and mount your choice of binding posts from here:
http://www.parts-express.com/cat/binding-posts/1506
post #6 of 6
Unless you've got a punch or want to file the hole by hand, I'd use these: http://www.parts-express.com/pe/showdetl.cfm?partnumber=090-475 . The others on that page require 'D' shaped or holes with flat sides to keep them from rotating in their holes.
