AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Sump Pump Failed - HT 2.0 Theater
Sump Pump Failed - HT 2.0 Theater - Page 2
post #31 of 32
I think my electric is moving forward OK, but I'm looking at the best place to buy insulation (probably getting it lowe's/ HD) and a drywall installer. I've interviewed 3, they had some range in price but none seemed too expert on my soundproofing ideas.
I'm looking at ceilings with RC, DD+GG, which they said they could all do.
post #32 of 32
Finished up my wiring. Ran new speaker wires (12 gauge) and ran power and RCA (coax) cable for extra sub placement.
My plan is to have a sub at the front and rear walls, dead center.
I finished up the insulation last night and the poly barrier. I pulled out some of the insulation I felt they did a bad job with the first time. I added more layers as well. I also caulked all joints and holes. I also put up 5 sheets of OSB (5/8") along the walls 3/4" up from the cement.
I'll put up some pictures before and after some of the OSB going up and the insulation done later tonight or tomorrow.
