AVS › AVS Forum › Audio › DIY Speakers and Subs › First Ever Fusion-8 Alchemy MTM Build Thread, Piano Black Finish
First Ever Fusion-8 Alchemy MTM Build Thread, Piano Black Finish - Page 4
post #91 of 100
I'd love to see/hear them as well though finding the time may prove impossible these days!
post #92 of 100
Yeah just haven't gotten around to taking a finished picture yet
post #93 of 100
I'm about to start on a pair of fusion 8s and is love to see some final pictures. I'm considering the same finish but it looks labor intensive smile.gif
post #94 of 100
yeah definitely very labor intensive. After this really dry winter the "cracks" where the wood joins each other seems to have made little ridges. So there's a few lines on the finish now, I'm going to try to fix it this summer. The nice thing about this black paint I used is that technically it never fully cures, so when you spray more on it it will basically melt into itself and form a new full layer. Here's some pictures I took with my phone. They came out a weird blue tinge. The second picture half the speaker is covered in dust. The last picture you can see the line that developed over the winter.
post #95 of 100
Nice grill, how did you attach it? Magnets or otherwise?
post #96 of 100
post 85 has some pictures of the grill construction. I have 4 neodymium magnets embedded in the front of the speaker, and the frame has 4 metal L brackets on the corners that stick to the magnets
post #97 of 100
Did you simply use a thick drill bit to get a hole for the magnets in the baffle?
post #98 of 100
Ouch on that line. I've had MDF telegraph through veneer and have seen it even in duratex (someone else's speaker). How do you plan on getting rid of it? Just spray more on or sand it out first.
post #99 of 100
yeah i used a drill bit the same size as the magnet and then i put some glue in and then hammered the magnet in.
post #100 of 100
yeah probably just lightly sand it with some high grit to get rid of the line and the wax on it and then re-coat and then re-wax
