AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sony KDL-60EX645 Wall Mount
post #1 of 4
Hi everyone! I just purchased my first tv and I want to mount it on the wall. I am weary about mounting it and wanted to get a recommendation on your experiences with mounting this 60 inch tv. I don't have a TON of money or I would just buy the most expensive mount out there to ensure its the best. I don't want to go with the cheapest version either (there's one on Amazon for 25$ that has a very high rating). Any help is greatly appreciated!
Thanks in advance!
Amy
post #2 of 4
I would look at monoprice.com and buy the cheapest mount that has the functions i need.
If you are more comfortable Amazon then $25 seems like a fair price. Using the proper construction techniques when mounting to the wall will be far more important that the mount that is used.
post #3 of 4
I saw that there are two different kinds, one with an open back and one with a full panel back. Are the ones with the panel backing sturdier? I saw a comment someone left saying not to buy the kind with an open back. But it was only one person...
post #4 of 4
Once it is mounted are you going to be touching it very often? I've only used the tilt type and once adjusted i never have needed to move the tvs so it doesnt seem to be of much concern. If you are getting the type that telescopes out and swings 90- 180 degrees then that may be an issue but since you said $25 i figured it was just a basic mount w/tilt.smile.gif
