AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Any good options other than Chief MWHVB for constant movement of TV
post #1 of 2
After looking at Monprice and Chief, it looks like the chief MWHVB is what I need. http://www.chiefmfg.com/Products/MWHVB
Anyone know of a similar mount (single arm 25" extension) that is less expensive and as well made? This will be moved every night from closed against the left wall to fully extended and turned. (see attached). TV is a 46" LED 30lbs.. Chief is $260. Placement will be on that left wall so it will be about where it is in the picture but a little bit higher. It is only used during the day or when I am not watching TV ;-) No little box for me..
Edited by airscapes - 8/1/13 at 5:24am
post #2 of 2
Bump.. I change the title to be move descriptive of the advice I need.
