AVS › AVS Forum › Display Devices › Screens › Feedback on ES M120UWH2 for Benq W1070, 13x18 dedicated media room
post #1 of 3
As the title says I have a dedicated media room 18x13, the projector I have chosen is Benq W1070, Screen, I am thinking about "Elite Screens M120UWH2 Manual Projection Screen (120 Inch 16:9 AR)". As its a dedicated room, I can leave it pulled down all the time. I am on a budget and want to keep aside as much as I can for the sound system. Few questions-
1. Is there anything significantly better about Fixed screen? is it worth the extra $200?
2. Is the screen size of 120 too big for a viewing distance of about 13 feet, should I down grade to 100?
3. Is there anything wrong if I proejct a smaller image in a 120 ft screen?
post #2 of 3
Hey. I just got exact same PJ and today ordered axactly the same screen. All i can get in a 3meter room is 100inch diagonal screen and its great for my usage(mostly PC gaming and a bit less movie watching)
So i think for 4meter room 120inch screen wont be too much. As i used to sit pretty close at my 37inch TV while gaming so my 100inch screen is just perfect fit for me. Just ordered 120inch so when i get larger room to set up PJ i wont need to buy new screen smile.gif
post #3 of 3
Hi ,
I have the same projector and dedicated media room of size 13 x 18 .I have the same questions. Did you get the answers? If so please share.
Thanks-
Satyam
  Back to Forum: Screens
