AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Signal degradation for long run HDMI cables
post #1 of 9
Hey guys,
As I was reading some of my favorite threads, I heard rumors of HDMI losing quality when the cable 20'+ long. Is that correct? If so, is it really bad, or something only a videophile will notice? What would be the recommended solutions?
I'm looking at a 30' to 40' HDMI cable to run from my receiver to projector. So far, I was looking at the Monoprice Redmere cables and they seemed like they might do the job; however, I noticed they're not CL2 rated, brought that to the attention of my electrician, and he's encouraging me to investigate other options.
Thank you,
Jonathan
post #2 of 9
There work or they don't work. You either have a perfect picture, no picture, intermittent no picture or a weak signal picture with sparklies and noise.
Always hook up your new cable in the same manner in which you plan on using it when installed in the wall, and try it for a week or so using max resolution 1080p 24 or 3D to make sure you will have no issues before you install it in the wall. I to will be doing the same thing you are shortly and expect to buy the same cables. I just wish they made them in a 25' and 35' length.
The site says the cables are VW1 rated right above the read TIP: I am not sure that is the same as CL2 but worth looking into.
Down near the end VW1 is explained.
http://www.southwire.com/support/WaCblTermsRating.htm
Still not sure if that is the same..
Edited by airscapes - 8/1/13 at 6:08am
post #3 of 9
Good catch on the VW1 rating. I'll run that by my electrician. Also, a great idea to run the cable outside the wall first.
post #4 of 9
Originally Posted by jklick View Post
Hey guys,
Thank you,
Jonathan
I've been using regular 24AWG/CL2 HDMI cable from Monoprice for about 2 1/2 years with no issues including 3D. Total length is about 45' with 2 couplers. The Redmere cable would be easier to work with though.
Hope this helps.
Ed
post #5 of 9
Hope this helps.
Ed
Thank you. This is promising feedback.
post #6 of 9
Thank you. This is promising feedback.[/quote
You're welcome! I bet the regular 24awg cable will work fine for you.
Ed
post #7 of 9
If you are cabling to a projector run the highest gauge Monoprice HDMI cable you can, run 2-3 pieces of cat-6 cable, and power. This will protect you for the future.
I've used Monoprice high gauge HDMI cables at 50+ feet without issue at all. You may get very visible signal loss, but if that is the case, then you can use a HDMI over cat-6 solution (HD-Base-T) which WILL work, and the cat-6 will protect you for the future.
Or, run conduit.
post #8 of 9
Another thumbs up for Monoprice HDMI cables. 45feet... NO issues whatsoever.
post #9 of 9
I happened to own a hdmi to VGA adapter. I then use cat5 to VGA adapters to run 75' in the back yard over 1 cat5. Looks a lot better that I would have expected. I also don't use it enough to get wound up about it.
