AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › Kaleidescape Cinema One...the cost of entry just got a whole lot cheaper .............
Kaleidescape Cinema One...the cost of entry just got a whole lot cheaper ............. - Page 7
post #181 of 194
Yes, and it is marvelous....
post #182 of 194
Originally Posted by aronsonstack View Post
Can someone explain the benefits of this over your usual HTPC and viewing your collection movie covers via xmbc, zappit, etc?
Is this just a product to make things convenient for the super rich?
That is covered earlier in the thread. But in a nutshell, you will not have to learn to build anything. It is ultra reliable compared to above solutions. Anyone can use it with ease. I have an HTPC that I use for everything other than movies and it is far less reliable and predictable than the Cinema One.
The other benefit is that you can buy movies online which today come as the same encodings as Blu-ray and in some cases, is available earlier than disc release. Gravity was an example. You buy the movies using any browser and it lands on your machine in the background. Once there, is no streaming, bandwidth issues, etc.
post #183 of 194
How does movie ownership work with K if you have more than one residence, can you view the movie at each location or do you need to purchase multiple copies of the movie?
post #184 of 194
If I got it right, you can store movies purchased in the Kaleidescape store on multiple (up to 5?) servers. However, if you own the movie on Bluray, you will need to buy multiple copies for mutliple servers.
Another option is of course to use a VPN, in which case you'll only need a server in one location...
post #185 of 194
Up to five Kaleidescape systems can be connected to the same movie store account.
Purchased movies download to all five systems, but you can also easily choose to download to particular systems.
This also applies to our disc-to-digital programs, so in the case where you own the movie on Blu-ray disc and we have it in our store with the necessary rights, you can pay just $1.99 to go disc-free AND have the Blu-ray quality movie downloaded to up to five systems.
Edited by Craig Heim - 3/10/14 at 5:47pm
post #186 of 194
is there a way to disable or change the sleep setting of the Cinema One?
mine goes to sleep after about 30 minutes of no activity: I would like to adjust that time longer: the screen saver setting does not seem to make a difference
I could do it with a timed event: sending a left cursor command every 30 minutes, but was wondering if there was an easier way...and if it might affect the life of the unit?
tia
post #187 of 194
tia
Under the General tab in the setup menu you can adjust or turn off the screen saver and switch between standby and full power down, but I don't see any options for what you are seeking.
To access this menu, press the MENU button on your Kaleidescape remote, scroll to the System tab, and select Settings.
For those of you interested in the full details, here is the manual: http://www.kaleidescape.com/files/documentation/Kaleidescape-Cinema-One-Installation-Guide.pdf
If you are using an IP-based control system, we have an event called LEAVE_STANDBY that could be used instead of sending a potentially undesirable command. I do not recommend sending this command every 30-minutes 24 hours per day. Instead send it on a source change.
Edited by Craig Heim - 3/12/14 at 7:29pm
post #188 of 194
One of the features with most value (IMHO) in Kaleidescape is the bookmarking that they provide. You can just press play and the movie starts: You don't have to sit or fast forward through a lot of trailers or other annoying menus. I love this feature. I'm sure you can achieve the same thing with a HTPC if you have the patience to bookmark all your movies. For someone with thousands of disks, it's just too tedious and effectively makes Kaleidescape worth what it costs, but YMMV.
post #189 of 194
One of the features with most value (IMHO) in Kaleidescape is the bookmarking that they provide. You can just press play and the movie starts: You don't have to sit or fast forward through a lot of trailers or other annoying menus. I love this feature..
Completely agree. This alone has made the system worth the money for me. I often find that I barely have time to watch a movie. Kaleidescape helps allow me that time by eliminating all the crap that used to surround trying to watch a movie. Love it!
Kevin
post #190 of 194
Glad to see the DV700 has now been repriced to $3995.
Quick question regarding the Go Disc Free option.
When you choose to get the Digital version from the store, remove your disc copy from the server, and download the Digital copy they aren't the same are they?
I mean the picture and audio are 1:1 copies but you loose the Blu-Ray menu, the chapter menu, and extras?
Is that correct?
post #191 of 194
Will there ever be a cinema one like product from Kscape that can ...
1. Store 100 BD's, but expandable to 1000 or more depending on HD configuration.
2. Operate completely independent of a vault, i.e. load a BD and throw the disc away, or download from the store.
3. Decode and output pcm for all audio codecs.
... I would buy one, almost irregardless of cost.
post #192 of 194
While I don't know the answer to your question, I do know what my dad would tell me when I would try to use that word...
Irre-g*d-d*mn-gardless
post #193 of 194
Your questions are obviously a "wish list" before buying, but as things currently stand.....
1. Current product can already do the 100 BD's, and although you can expand that number it requires buying another C1. There "was" a plan to build an external storage device that would increase capacity, but there have been comments that this is no longer being considered (but that might change).
2. Current product can do that now, but you must download from the K Store to be "disc free", and as you likely know, not all major studio's are available in the Store (but more are likely soon).
3. We have been asking for this for quite awhile, but it has not been a priority because of the relatively few K owner's that own processor's incapable of decoding the bitstream. It would be nice to have (for those owners), but may be awhile, if ever.
Jim
post #194 of 194
I agree this is highly unlikely.
You could use this if you have a 7.1 input.
https://www.gefen.com/pdf/onesheets/GTV-HDMI-2-HDMIAUD.pdf
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
