AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Can't click on images to go to gallery view, or see larger one reliably
post #1 of 4
It used to be a piece of cake for me to see the large size of someone's image in a post (and not the reduced size by the insert-image utility fired up from the image icon in the message editor).
Now I can do it only rarely.  Just happened now once but I cannot replicate it.  Do I have an assumption gone awry?
I'm using FF 22.0 (PC---Win xp)
post #2 of 4
Hi,
If you can provide examples of where it works & doesn't work, we can take a look and try to find the cause.
post #3 of 4
Well, perhaps this is more telling, and then I'll go back to the click through.  For some reason, now I seem to be able to click through from the post smaller image to this gallery view image:
http://www.avsforum.com/t/1460590/lightbox/post/23587939/id/250917
But the page keeps auto-scrolling to the bottom saying "Missing Images?"  Weird, because the image is there, but it's scrolling the page down without my control.
Whoops----and just now it seems to have stopped that behavior.
This is getting more and more twilight zone....
post #4 of 4
  Back to Forum: Forum Operations Center
