AVS › AVS Forum › AVS Forum Information › Post Testing Area › Test-Test
Test-Test
post #1 of 3
post #2 of 3
If you've not opened those yet for super chunks it's best to use cheap pink fluffy, due to gas flow restively.
Look at DIY acoustics link in my sig for explain, I can't link to that from my iPhone easily .
Happy building big bass traps.
Via my iPhone 5s using Tapatalk
post #3 of 3
MAKE BriteView Channel Master CM / Entone Channel Master Digital Stream DVICO TViX ePVision Philips/Magnavox iView Moxi TiVo TiVo
MODEL BVT-980H CM7000 /DTVPal CM7400 / 458 DVR+ DPH 1000R M6620N PHD - VRX/2 HDR5710/5750 3500 STB HDMR 1500T3 S3/HD/Premiere/ P4 Romanio
Cost new ($) 165 320 380 250 230 300 230 249 / 299 >40 500 / 600 - / - / 100 & up xxxx
Cost used / open box ($)   220 260   190       (also HW-150) Mate 120 S3-330 / P-480 xxxx
Authors rating * ***½ ** / ** *** * *** *** ** *** *** ***½ xxxx
HARDWARE BriteView Channel Master CM / Entone Channel Master Digital Stream DVICO TViX ePVision Philips/Magnavox iView Moxi TiVo xxxx
Tuner types; ATSC / QAM / NTSC 1 ATSC /  QAM 2 ATSC 2 ATSC / QAM 2 ATSC 2 All 2 ATSC / QAM 2 All 1 All ATSC / QAM 2 or 3 QAM All except Prem4 xxxx
Combined analog & digital tuners --- --- --- --- No --- Yes Yes --- --- Yes xxxx
RF inputs One One One One One One Two One One One Two except Prem4 xxxx
HD Video outputs: HDMI / Component HDMI Both Both HDMI Both HDMI HDMI HDMI Both Both Both xxxx
Digital audio outputs: Optical / Coaxial None Optical Optical Optical Optical Both Optical None Coaxial Both Optical xxxx
Front panel display type text or LED's LED LED Clock & LED LED Led Full Text Both LED Both LED LED xxxx
Front panel functions; transport and/or menu None None Menu Standby Menu Menu & PB Menu & Ch. Standby Pwr, ch up/dn Menu S3 Text / LED / LED xxxx
Power consumption; operating & standby 9 / 1 23 / 21 24 / ? 20/ 1 15 / 1 ? 20 /HD / 1 22 wHD / 15 / 2 20 w/HD / 1 9 wHD / 7 /  1  26 / Mate 10 S3-34 / S4-26 xxxx
HDD: internal stock/maximum external size 320G / No 250G / No 320G / Yes None/ 3TB 320G / 2TB None / 2TB None / 2TB 4TB ? / 4TB None / 1TB 500G / 6TB 250 / 160 / 320 - 1TB xxxx
HDD spins down in standby Yes No No? ?? Yes Yes Yes ?? Yes No stdby No stdby xxxx
External record: HDD / Memory stick Stick None Both   Both Both Both HDD Both Yes / No Yes / No xxxx
Low power standby Yes No No Yes Yes Yes Yes Yes Yes --- --- xxxx
Boot time from standby 30 sec --- --- ?? 30 sec 30 sec 30 sec ?? 10 sec  --- --- xxxx
HDD file system (format) NTFS DFS–Proprietary EXT3 EXT3 NTFS NTFS EXT2 Linux O/S NTFS Linux ? MFS – Proprietary xxxx
Hardware build quality ? Fair Fair/Good ? ?? ? Poor Good ?? Fair Good ? Good xxxx
TUNERS & CHANNELS BriteView Channel Master CM / Entone Channel Master Digital Stream DVICO TViX ePVision Philips/Magnavox iView Moxi TiVo xxxx
Separate OTA & CATV channel scans No --- No Text No No Yes Yes No No scan No xxxx
Add channels not in the original scan Yes ? Yes ? Text Yes ? No Yes Yes Yes --- Yes w/ 2nd scan xxxx
Add channels via physical numbers No Yes ? Text Yes ? Yes, no sub Yes ? Yes No No xxxx
M Cable Card support No --- No Text No No No No No Yes Yes xxxx
Edit channel names and/or call letters No Yes Yes Text Analog ? No Call letters ? Call letters No No xxxx
Ability to re-map QAM channels No --- No Text No No No ? No  Yes No xxxx
Signal strength indicator No Yes Yes Text Yes Yes Yes ? Yes Yes Yes xxxx
Skips encrypted QAM channels ? --- ? Text ? ? Yes ? Only some Yes via CC Yes xxxx
Skip channels in guide that are in the ch. list ? No  ? Text ? ? No No guide Yes ? S3-No / S4–Yes xxxx
PROGRAM GUIDE & RECORDING BriteView Channel Master CM / Entone Channel Master Digital Stream DVICO TViX ePVision Philips/Magnavox iView Moxi TiVo xxxx
Program guide; PSIP and/or Pay (full) PSIP PSIP Both Text PSIP dig. only PSIP PSIP No guide PSIP Full Pay only xxxx
Fully usable without additional fees Yes Yes Yes Text Yes Yes Yes   Yes Register DVR No xxxx
Number of days of programming Varies Varies Varies / 14 Text Varies Up to 1 Varies
Less than 1
14 7 xxxx
Grid type of guide No Yes Yes Text No No No   No Yes Yes xxxx
Combined or separate guide for all tuners --- Comb. Comb. Text Comb. Comb. Sep.   --- Comb. Comb. xxxx
12 or 24 hr clock 24 hr 12 hr 12 or 24 hr Text 24 hr 12 or 24 hr 12 hr 12 hr 24 hr 12 hr 12 hr xxxx
Time setting; auto and/or manual & source Manual Both / PSIP Both / PSIP Text Both / PSIP PSIP / NTP NT / PSIP  Man Both / Station PSIP Auto / NTP Auto / NTP xxxx
QAM channels listings w/o using a CC Varies w/MSO --- Yes w/sub. Text Varies w/MSO Varies w/MSO Varies w/MSO   No Yes No !! xxxx
Jump fwd & back in Guide No 1-8 days 3 & 24 hrs Text No ? ? Page up/down   No 24 hrs Not in Grid view xxxx
Guide search by program names No Yes Yes Text No No No   No  Yes Yes xxxx
Save program searches No Yes Yes Text --- --- ---
Yes Yes xxxx
Manual recording VCR style Yes Yes Yes Text Yes Yes Yes Yes Yes  Yes Yes xxxx
Protect recordings from deletion No ? Yes Yes ? Yes Yes   Yes Yes Yes xxxx
Record only new episodes No No Yes Text No No No   No Yes Yes xxxx
Name and/or time based recordings Time Time Name (pd G) Text Time Time Time Time No Name Name xxxx
Auto-adjust for changing days / start times No No No Text No No No No No Yes Yes xxxx
Recording conflicts action; auto or manual No Manual Manual Text Manual Manual Manual Manual Manual Manual ? Auto xxxx
Auto pad recordings start & end in Guide No No Yes Text Indirectly No No No Yes No Yes xxxx
Number of programs recorded at once One Two Two Text One Two Two One One Two or Three 2 / 2 / 2 / 4 xxxx
Record indicators of future programs ? Yes Yes Text From guide Yes Yes in Rec list   In Sch. list Yes No xxxx
Available HDD space shown ? Yes Yes Text Yes Yes Yes Yes Yes Yes No / No / Yes / Yes xxxx
Adjustable buffer time amount No No No ? Text No buffer Yes Up to 4 hrs No buffer Yes No No xxxx
Closed Caption available in playback No Yes Yes Text No No Yes Yes Yes Yes Yes ? xxxx
PLAYBACK & MISC BriteView Channel Master CM / Entone Channel Master Digital Stream DVICO TViX ePVision Philips/Magnavox iView Moxi TiVo xxxx
Dedicated play & stop & standby buttons Yes Yes Yes Text Yes No play / stop Yes Yes Yes Yes No stop or Sttdby xxxx
Remembers where playback left off Yes Yes Yes Text Yes Yes Yes Yes Yes Yes Yes xxxx
Skip ahead or back time amounts None Both; 30 sec Fwd; 30 sec Text None Both: variable Both to 2 min Yes, many No  Fwd variable Fwd 30 sec hack xxxx
Edit recorded program name ? Yes ? Text Yes Yes No Yes (auto titles) Yes No No xxxx
Recordings encrypted within HDD No Yes Yes Text No No No ? No Yes Yes xxxx
Record history showing errors Shows failed Yes No ? Text Yes No Yes (limited) In title list No No ? Yes xxxx
PC / USB file transfer ability No / Read No / No No / Yes Text No / Yes No / Read Yes / Yes ? No / Read Yes / No Yes / No xxxx
Media Player No No Yes Text Yes Yes Yes No Yes Yes Yes xxxx
Create playlists for external media --- --- Yes Text No Yes No Not No No No xxxx
Ethernet: wired/wireless No No Both Text No Both Wired Both No Wired Both xxxx
Internet services available --- --- Hulu Text --- None U Tube Various --- Numerous Numerous xxxx
Multiple room recording and/or viewing --- --- No Text --- Yes No No --- Yes w/Mate Yes w/extende xxxx
Firmware upgrade; Internet and/or USB USB USB Both Text None available Internet USB Both USB Internet Internet xxxx
Available support; on-line and/or telephone None Limited Limited  / None Text Very Limited Very limited None / Limited Both Both, but limited Both ? Both – Good xxxx
Edited by videobruce - 1/7/14 at 3:05pm
  Back to Forum: Post Testing Area
