AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Optoma HD131Xe, HD (1080p), 2500 ANSI Lumens, 3D-Home Theater Projector - Sub $800 New Budget King?
Optoma HD131Xe, HD (1080p), 2500 ANSI Lumens, 3D-Home Theater Projector - Sub $800 New Budget King? - Page 72
post #2131 of 2563
Originally Posted by bd2003 View Post
I guess what I really want in the end is a better projector. But nobody does 3D and gaming as well as optoma, and they don't have a model with better contrast performance....so I guess I've gotta live with it's limitations.
You know you make this comment right after I put in the order for this projector at amazon. Luckily I came in read this before anything happened. I cancelled my order. I wanted the benq in the first place but the throw distance and screen placement would have worked better with this projector. I just know I wouldn't be able to live with the color on this one. So, on the lookout for something else.
post #2132 of 2563
The color seems fine in practice even if it doesn't measure perfect. It's the black level that's my gripe with it, and I don't think the benq is any bette.
post #2133 of 2563
No the benq has better color, worse contrast I believe is the comparison. I'd rather have the color personally.
post #2134 of 2563
We are talking about a $700-750 projector.
It's not going to be perfect at anything.
I am quite pleased with mine considering I walked in knowing it would be a budget setup for my first setup to see how I liked projection.
I would never compare it to a higher end model though.
It's great for what it is, but don't expect the output of a higher end unit
post #2135 of 2563
Yeah. I just wish there was a clear model to step up to. What other DLP PJ in the 2K range has good input lag and RF 3D glasses?
post #2136 of 2563
the next step might be a different brand.
They dont carry better model Optomas for a higher price?
post #2137 of 2563
Thanks to anyone who helped me with mounting this PJ. finally got it up and running lol.
Digging it so far!
post #2138 of 2563
good to hear man. Enjoy it!
post #2139 of 2563
Originally Posted by Redogfizbal View Post
FWIW - They told me the same thing in chat and I never got my credit. It's been over 2 weeks now.
post #2140 of 2563
You have to checkout with an item before you can see the credit
post #2141 of 2563
I also told in chat and found that the projector had to be delivered before the credit would appear during checkout.
Edited by Cyrano - 2/7/14 at 7:48pm
post #2142 of 2563
I was told the same thing. Amazon is one of the few companies I trust my money with.
I received my optoma at noon today. I am very happy with the picture quality. One thing that made a huge difference was using the settings that I posted earlier. It almost completely eliminates any type of noise. Granted there are some movies that just have noise no matter what you do, but I am very happy with the colors, and black levels with those settings. The noise level of the projector is also very low, this is important to me as I am 60/40 music movies. My projector also came with a lense cap. The only complaint I have is the remote and menus are far to sensitive, I have to be very fast at pushing the buttons not to go to far.
post #2143 of 2563
Need help!
Why do I have bars on my 16:9 screen on the top and bottom, with a 16:9 projector?
post #2144 of 2563
You're watching a movie that is 2.35 aspect ratio. Many movies are.
16:9 movies are 1.78 (sometimes 1.85) aspect ratio. 4:3 movies are 1.33 AR.
http://www.widescreen.org/aspect_ratios.shtml
http://en.m.wikipedia.org/wiki/Aspect_ratio_(image)
Edited by Cyrano - 2/7/14 at 8:53pm
post #2145 of 2563
Can you guys check out my calibration settings and give me some feedback. I'm projecting over 160 inch and it looks great. The image is very bright even at over 180 inches.
Brightness 0
Contrast -3
Sharpness 9
Color 5
Tone 0
Gamma Graphic
Brilliant Color 1-3
Color Temp Cold
Red -3 5 -4
Blue -11 12 50
White -16 13 30
Everything else Saturation at 10
post #2146 of 2563
Brightness 0
Contrast -3
Sharpness 9
Color 5
Tone 0
Gamma Graphic
Brilliant Color 1-3
Color Temp Cold
Red -3 5 -4
Blue -11 12 50
White -16 13 30
post #2147 of 2563
Sounds like you're giving us good feedback about how good this projector can do with a large projection.
Maybe others can help you; I am just glad to hear such a large image can prove satisfying.
Enjoy!
I cannot question what works for you.
Here are the numbers I use:
Display Mode:User
Brightness:0
Contrast:-3
Sharpness:9
Color:9
Tint:2
Advanced
Noise Reduction:0
Gamma:Film
BrilliantColor:1
Dynamic Black: High (The fluctuating sound can be a bother to some. It is not to me.)
Color Temperature:Warm
Color Settings:White - Red 0/Green 0/Blue -1, Red - Hue 0/Saturation -1/Gain -10, Green - H 10/S -2/G -3, Blue - H 10/S 0/G -22, Cyan - H 8/S -4/G -3, Magenta - H 19/S 4/G -16, Yellow - H 20/S -7/G 4
Color Space:Auto
Format:Native
Edited by Cyrano - 2/7/14 at 11:59pm
post #2148 of 2563
Dammit! I though I had found the ideal projector for what I wanted to do here, but i have some issues and was after some advice on where to go from here.
I wanted this for gaming, specifically for sim racing. This means I will be sitting at a specific distance from the screen, and the screen needs to be low or it'll be all wrong. In sim racing, you try to match the view you see to how it would be sitting in a real car, so if I ceiling mount the projector, the screen will be very high up, and that means the windscreen for the entire car will be miles too high.
So anyway, screen needs to be quite low down.
The issue is this: If i was to try a table top style position, it will have to be in front of me, and there is no space as that's where I'll be sitting, slap bang infront of the center of the screen. If i ceiling mount, screen is far too high up.
I need Lens Shifting.but the Optoma doesn't have this, in all others ways it's absolutely perfect. I do not want to use Keystone.
So what are my options at this point if i cannot go for the HD131XE? Any suggestions?
post #2149 of 2563
You are most certainly better with the optoma if you ceiling mount.
It has a decent. Image offset so that may work well for you to put the image low. More offset = lower image if ceiling mounted
If I wouldn't have mounted up between my joists my image would have practically been on the floor
So I tried the wow disc again last night and modified the base settings quite a but from what has been posted. I played with the blue filter for the first time and actuallyt tried to smooth out the colors.
I'm gonna watch a movie today to see what it looks like. But it was pretty far off what has been posted here soon far.
Cyrano, what do you notice the dynamic black do? I haven't even noticed any affect other than fan on high and fan squeal every few rotations
post #2150 of 2563
Hi PM.
My projector operates practically in another room shooting its light through a hole in the wall. So the sound fluctuations are virtually unheard.
The effects of dynamic black are subtle and if the sound is noticed I wouldn't use it. I do think the lamp is used in variable brightness mode that is so fast it is not noticable. (I am just guessing here; IDK.)
I use it and don't hear it. There was a similar feature with my previous Optoma projector, the HD70, that was so loud that I didn't use it. And I recall that one could see the dimming of the light a bit so it was not invisible in its effect. This dynamic black works, I think, and very invisibly. But the noise is not worth the slight improvement to the black level if you notice the noise, IMO.
Also, you mentioned a few posts ago how little effect the eco setting has on the brightness levels. I noticed that too. One might as well use eco and get the increased lamp life.
And if the image begins to appear dim after a couple of thousand hours just use the brighter mode. This PJ does have a good option to achieve renewed image quality as the lamp ages.
post #2151 of 2563
Is there a relatively cheap way to convert to the lens to 2:35?
post #2152 of 2563
Do you have room for a short throw PJ, like the Optoma GT760? It just needs to be a few feet from the screen to throw a large image. Supposed to be an excellent low lag gaming projector.
post #2153 of 2563
That's something I'm interested in too. Here's a thread about that. And check out the forum it's in.
http://www.avsforum.com/t/1515766/2-35-1-newbie-novice-questions#post_24305339
Here's the 2.35 forum:
http://www.avsforum.com/f/117/2-35-1-constant-image-height-chat
Edited by Cyrano - 2/8/14 at 10:09am
post #2154 of 2563
So I think I got this thing dialed in pretty good now to my novice eyes.
Skin tones look a bit more natural. The other settings posted I found a tad too cold.
My settings do indeed seem a tad warmer but I like it.
Blacks seem to be more dialed In and whites not as bright.
Quite a bit of black shadow detail and nice black scenes, but still lose some of the detail in like black velvet clothing for example.
Deff not up to par with plasma, but again for its price range and total budget I put on my setup, I can't expect it to be.
I just watched Star Wars ep 3 and not the slightest bit of grain. I was very happy with its performance.
To cyrano: I only noticed the fan noise with the dynamic black up when the sound was low. It annoyed me then, but with a movie playing my audio over powers it easily. Lol
I just didn't notice any difference so I shut it off.
Maybe I'll play with it another day
post #2155 of 2563
Very disappointed by the state of my projector. Looks like it needs to go back. There is a circular"hot spot" now. Almost looks like a compact disk reflection. Hard to see with camera shot so I used filter effect to see better
Edited by hyperactiveme - 2/8/14 at 11:42am
post #2156 of 2563
That sucks. How old is it?
Edit::::: just saw you got it back. Man that really sucks bad. Sorry to hear man
post #2157 of 2563
Yeah it does but optoma is a pretty solid company. Hopefully they'll cover the $25 shipping or let me drop it off.
post #2158 of 2563
I don't think it has enough offset for me. Screen will not be larger than 70inchs, so the offset goes down. The top of the screen will start 70cm below the ceiling, so it will have to hang very low off the ceiling for it to work. I also would then have to worry where i sit may actually be in the way of the bottom part of the image unless the throw distance is really short for this size of screen.
I though the benq 1070 might have been my saviour, but it's len shift is literally a few inches, too. I seem to be out of luck if i want to stick to this type of budget, nothing will work from what i can tell. I'm new to the idea of owning a projector, hence why i'm kind of learning this stuff as i go here.
Considering i will be sitting quite close to the screen, i think it's best i go with a 1980p model. also, the image will be too high up near the ceiling, it needs to be 70cm lower. I'm quite sure at this point, all models without 50% lens shift are going to be out for me. If anyone thinks differently, let me know!
post #2159 of 2563
So you need something with more offset.
I think mitsubishis have this. Some view sonics are like this too.
But sounds like you are gonna have to make some compromise
70 inches and down low without worrying about obstructions isn't gonna happen imo.
If you want it low, you will need to mount it low wit no offset
Edited by PM-Performance - 2/8/14 at 5:55pm
post #2160 of 2563
Enjoy!
Display Mode:User
Brightness:0
Contrast:-3
Sharpness:9
Color:9
Tint:2
Advanced
Noise Reduction:0
Gamma:Film
BrilliantColor:1
Color Space:Auto
Format:Native
I cannot seem to find an option for color. Just Brilliant color.. ?
