AVS › AVS Forum › News Forum › Community News & Polls › Changes coming to our advanced editor
post #1 of 3
Most AVS members use the default basic editor (the box you type posts into) which looks like this:
Some of you who want more advanced formatting options may have opted for the CK Editor (rich text editor) from your profile settings which looks like this:
If you're using the default editor, no changes will be seen. If you're using the CK Editor, that's getting a bit of an upgrade.
The new version will have a quick mode:
And an advanced mode:
You can toggle between quick & advanced directly from the editor without needing to go to your profile page.
More details will be available once it launches (hopefully later this month), but here is a quick reference chart to show the differences between what the current CK Editor can do compared to what the new Quick & Advanced modes will do:
post #2 of 3
Are there going to be any changes to the mobile editor?
post #3 of 3
No, this is only for the desktop editors.
  Back to Forum: Community News & Polls
